Tip & How-To about Computers & Internet
To clear BIOS password
Wants to clear BIOS Password Key
>Open CPU
>move Jumper 2 2-3 pstn from 1-2
>start PC
>go2BIOS
>clear it
>turn off
>move J to 1-2 & d
Computers & Internet Logo
I need the main login password for a compaq 2103
At some point someone installed a BIOS password on your PC. Open CPU >move Jumper 2 2-3 pstn from 1-2 >start PC >Go to BIOS >clear it >turn off>move the jumper back to the original position. Restart PC. Be careful you have touched bare metal before touching anything on the motherboard. You don't want to zap it with static electricity.
Jan 17, 2013 | Compaq CQ2103WM-B (884962083048) 17 in. PC...
restore factory password
open your CPU Cover and near bios cell you can see that here is a jumper in 2 pins pull out it, and then start your cpu for a minute and power off it then plug jumper in pin 2 and 3 then start your cpu again for a minute and power off it then pull out jumper and plug it in pin 1 and 2 as it was and then start your cpu password is dessolved.
Jun 17, 2011 | Computers & Internet
reset bios password for IBM Thinkpad A31 Intel CPU MotherBoard 93P3542
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 19, 2009 | Computers & Internet
don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
398 people viewed this tip
David Payne
David Payne
