Tip & How-To about Vacuums
Extend a Vacuum's Hose "Lifespan"
There are several things that can lead to a fairly short "life span" on a vacuum hose. Hoses need to be replaced periodically anyway, but getting the maximum use means reduced cost for your investment. Common problems are: worn out hose, leaky hose, broken wire, loose connections, and of course, clogs.
Normal wear and tear may seem to be a problem that there's no help for, however anyone can reduce this on their vacuum hose. Some examples include:
Hang hose properly. Improper storage may promote wear on the hose and stress on the wiring. I recommend detaching from vacuum and wands, and hanging across two large hooks or hangars. This places weight upon two areas of hose, instead of just one.
Placing a hose sock on the hose will help reduce wear and tear caused by dragging back and forth on the floor, corners, and other surfaces. The heavier the fabric, the better protection.
Pulling the vacuum behind you while cleaning creates high stress on both the hose material and internal wiring. Indications of problems are loss of airflow/suction at end of hose for the first, and power nozzle not operating or intermittently operating. Avoid pulling vacuum behind you; move vacuum closer to the cleaning area to clean.
Loose connections are pretty much inevitable over time. The connections from hose to wand, wand to wand, and wand to power nozzle all are susceptible to wear and breakage. Replace hose and wand connections that are broken, loose, and/or blackened. Those things can cause bad electrical shock.
Clogs are often caused by a large item being vacuumed, but more often are due to a long, thin object being sucked up, sticking in the hose, and other stuff backing up against it. This will eventually cut off air flow and result in a burned out motor if not remedied.
Maximize your vacuum hose’s use by following the above suggestions.
Vacuums Logo
brushes don't move. vacuum motor works
The brushes on the roller are driven by a wide, short rubber belt. These belts get old, worn, overheated, and break periodically.
It should be a fairly simple matter to unscrew & remove the plate, revealing the belt and roller assembly. You can get a replacement belt at Sears or nearly any vacuum shop.
While replacing the belt, it would be a good idea to take scissors or a knife (careful!) and remove the hair & other material that's wound around your roller. One thing that can cause a belt to break is when you're vacuuming & accidently pick up a string, a shoelace, a piece of cord... you know how fast that gets wound around the brush roller and locks it up? At that point, the belt is still trying to rotate the roller (which won't rotate)... and within seconds, the belt will get extremely hot. This can cause it to break, or reduce its life significantly.
This should be an easy fix, requiring nothing more than a replacement belt and a screwdriver. Good luck!
Mar 03, 2011 | Kenmore 31913 Progressive Direct Drive...
Our carbon monoxide dectector model CO910, bought several years ago (10+) beeps every 30 seconds with an "err" message. All windows where it is are open. No one is feeling ill. Is it just an error on the detector and it is time to get a new one?
CO2 and Smoke detectors have an internal sensor that has a design life of 5 years from the date of manufacture. After the 5 years you start getting false alarms due to the sensor itself exceeding its average life span. On the combination CO2 and Smoke deterctors you will often see a manufacture date or a replace by date inside the cover on the main board.
On AC powered models such as this one you will just get the error when the sensor fails. If you got the full 5+ years out of your CO2 sensor then you should be happy that it served a full life expectancy.
Some Wiki data on CO2 detectors:
http://en.wikipedia.org/wiki/Carbon_monoxide_detector
This paragragh appears under installation
The gas sensors in CO alarms have a limited and indeterminable life span, typically two to five years. The test button on a CO alarm only tests the battery and circuitry not the sensor. CO alarms should be tested with an external source of calibrated test gas, as recommended by the latest version of NFPA 720. Alarms over five years old should be replaced but they should be checked on installation and at least annually during the manufacturers warranty period.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Vacuums
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Empower Widepath Vacuum Doesn't ****
This model requires the lower end of the hose to be installed into the base unit to pick up the dirt. If it is properly installed, I would check the belt and also look for a blockage. The normal life span of a belt is about 9-12 months. your belt # 40201190 2 pk
Mar 11, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Overheating Hoover
Most likely caused by a lack of airflow. Check to see if you have airflow at the end of the hose. If not, Remove all of the hoses and ensure that they are not clogged. If there is airflow through the hose; check the air inlet immediately aft of the brushroll, inside the nozzle. This is a very common place for clogs to form.
Also note: contrary to some manufacturers claims, you can not clean (or wash, for that matter;) a hepa filter. The small particles are too embedded in the filter media to ever get completely removed, and the act of cleaning tends to damage the filters, even if you can't see the damage. This is why bagless life-spans, on average, are half the length of the life-spans of bagged vacuums.
Good luck,
-R
Aug 01, 2008 | Hoover U8145-900 Savvy Bagless Upright...
370 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
