Tip & How-To about Computers & Internet
Create a Windows 7 Password Reset Disk to Reset Windows 7 Password Easily
More and more people today tend to forget or lose their Windows 7 password under such a high-pressure society. Then what would you do to handle with that should you experienced the same trouble? Actually, all you need is only a "password reset" disk. A Windows 7 password reset disk could help you to reset Windows 7 password and regain access to your locked Win 7 PC. Here we will share two methods to create such a disk with you. So let's roll it.
Method 1: Through Windows 7 operating system
Requirement:
1. Be able to log on Win 7 operating system with the password
2. A USB flash drive is required
Windows 7 was designed to be able to create Windows 7 password reset disk without any other third party tools. So if you forgot the password for your user account and was unable to log on, then you could use the disk to reset Windows 7 password. Now you could follow these simple steps to create one.
Step 1: Start your computer and log on Win 7 operating system
Step 2: Insert an USB flash drive into your computer
Step 3: Click Start -> Control Panel -> User Accounts and Family Safety -> User Accounts -> Create a password reset disk
Step 4: You will see the welcome screen. Click Next
Step 5: Select your USB flash drive. Click Next
Step 6: Type the login password in the password field. Click Next (now Windows 7 operating system should automatically create the disk for you)
Step 7: When the processes finish, Click Finish to exit
Now you have successfully created a Windows 7 password reset disk. And you will be able to use this disk to reset Windows 7 login password by following the whole processes of Windows 7 password recovery if you forgot Windows 7 password.
Note: One disk can only work for one account. You could not use this disk to reset the password of another user account.
Method 2: Try Windows 7 password reset software
Requirement:
1. An available computer with a CD/DVD burner
2. Windows password recovery software
3. A blank CD/DVD or USB flash drive
There is plenty of third party Windows password recovery software on the Internet. All of them were designed to create a Windows password reset disk. If you forgot to create a Windows 7 password reset disk when running Win 7 operating system before losing your password, then you may have a try on this method. The benefit of this method is that you could create the disk any time and do not need to know the Windows 7 password. Here we highly recommend Windows Login Recovery and will take it as an example to explain the procedures.
Step 1: Download Windows Login Recovery and install it onto an available computer
Step 2: Run the software and use it to burn a Windows 7 password reset disk (you could burn the file onto a blank CD/DVD or an USB flash drive)
Step 3: Change the BIOS setting of your locked computer to make it boot from the optical drive
Step 4: Boot your locked computer from the created disk and reset Windows 7 password
If you do not think these steps are distinct enough, you could also view the detailed user guide at recover the forgotten Windows password. By the way, the disc created through this way can reset the password of all the accounts instead of only one account.
Forgetting Windows 7 password is really a problem. But now you needn't worry about that any more. You could easily reset Windows 7 password with your Windows 7 password reset disk in the future.
Computers & Internet Logo
forgot administrators password, have no reset disc, windows 7. need pathway in command promt
This article describes how to reset windows 7 password without disk when forget login password and locked out of your laptop or computer.
If you are still bothered about forgetting windows 7 password and have no reset disk, the methods described in this article will help reset the lost password with or without disk. You just need a few minutes to read these methods in this article, and pick the right one to take it to carry out.
Method 1 and Method 2 describe how to reset a user account password under the condition that you can login your comptuter with another administrator account.
Method 3 shows how to reset a lost password with windows 7 password reset disk which you have created before forgetting login password.
Method 4 tell you how to reset or recover windows 7 login password with a password recovery software.
Sep 11, 2013 | Computers & Internet
How fast can you reset Windows 7 password?
As far as I know, Windows Password Recovery Tool 3.0 is safe and easy to use. An .ISO file included in windows passwords Recovery. So, you just need to free download windows passwords Recovery, which is available at many download sites like http://www.windowspasswordsrecovery.com
Jul 07, 2010 | Computers & Internet
I forgot my username and password how can override im using windows 7.
Windows 7 allows us to create a Windows password reset disk (USB key) in case that we lost the Win 7 logon password. When we lose the password of Win 7, we can reset a new one with the created disk. The weak point is that you can only create the disk before losing your Windows 7 password. If you do not create that, it could not help.
If you have an available administrator account on your system, you can get your password back easily. Logon Win 7 system with the admin account, and then you can come to the Control Panel and change or delete other accounts' passwords. Just three steps:
Step 1: Click Start -> Control Panel -> Add or remove user accounts
Step 2: Choose the locked administrator account
Step 3: Click Change the password or Remove the password. And then you can change or remove the lost or forgotten password
If you do not have another available administrator account, you could try some third party software. There is plenty of third party software for password recovery on Windows 7 online. all of them are designed to create a Windows password recovery disk. With the disk you can recover your lost Windows 7 password. I highly recommend Windows Password Recovery Tool 3.0 and use it as an example. What you need to do is just three steps (you need another computer to create the disk):
Step 1: Download Windows Password Recovery Tool 3.0
Step 2: Burn a Windows password recovery disk with the software
Step 3: Create Windows 7 password reset disk
I think the most efficient is using third party Windows password recovery software. Have a try.
Sep 04, 2011 | Computers & Internet
unlock code
The greatest sin in today's world is to give a password and then forget it. You must pay the penalty of losing all data. The only way out is to get the firmware re installed. Thus losing all data. Problem with all of us is that we tend to forget things sooner or later. In future do not use a password. If you have to, then it should be such that you do not forget it.
May 27, 2010 | Nokia N73 Cellular Phone
172 people viewed this tip
David Payne
David Payne
