Tip & How-To about Computers & Internet
INTERNET CONNECTIVITY SPEED IS SLOW DUE TO MODEM
Hi People ,
If you experience a slow internet connectivity speed with belkin Basic , Surf , Play , Modem . Just Login to 192.168.2.1....Select connection TYpe PPPOE change MTU Value to 1452
Cheers
Computers & Internet Logo
slow internet belkin 600 db
You can better use the Torrent for Uploading and Downloading flies and videos,the streaming and buffer depends on the site you using for watching video,because traffic increase means you network speed get slow,so better use good and latest browser,reset the modem everyday and check the speed of the internet at here Scanmyspeed.com
Jan 16, 2012 | Belkin Play N600 Wireless Dual Band Router...
Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable. Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable. Open internet explorer / Firefox or any of your default web browser. In the address bar type the default gateway address of Belkin router 192.168.2.1 Belkin router setup page (RSP) will be displayed. Login to the page. (password: leave it blank and click submit) On the left side below the "utilities" select firmware update and check the current firmware version of your router. For belkin basic (F7D1301) router the latest firmware is ver.1.00.16 to download the latest firmware for basic router click here... For belkin surf (F7D2301) router (older firmware ver.1.00.10) the latest firmware is ver.1.00.15 to download the latest firmware for surf router click here... For belkin share (F7D3302) router (older firmware ver.1.00.13) the latest firmware is ver.1.00.18 to download the latest firmware for share router click here... For belkin play (F7D4302) router (older firmware ver.1.00.14) the latest firmware is ver.1.00.20 to download the latest firmware for play router click here... For belkin playmax (F7D4301) router (older firmware ver.1.00.15) the latest firmware is ver.1.00.21 to download the latest firmware for playmax router click here... In these updated firmwares all the problems related to various issues have been fixed. download the latest firmware and update it. After updating the firmware click on restore factory defaults found below the "utilities" and restore it. then configure your router according to your internet service provider... For Cable ISPs click here... For embarq and centurylink ISPs click here... For DSL & Satellite ISPs click here.... To configure the wireless part except for play & playmax click here...
Jul 24, 2010 | Audio Players & Recorders
I bought a Belkin 'Play' router to provide wireless internet connectivity from my CLEAR modem. I can't get the router to speedtest at half the speed as being directly connected (via ethernet cable) to the CLEAR Motorla modem. I'm by no means a router expert (more like a novice), and so I've tried every configuration I can find on the internet and nothing seems to help. And, yes, I have a 3+ feet distance between the modem and the ROUTER. Any suggestions are appreciated.
Use an Ethernet cable from the CLEAR modem into the WAN (or 'Internet') port on the Belkin.
Take a close look at the 8 coloured wires at each end of the Ethernet cable.
The 8 wires must be coloured in the _same_ order at both ends.
Be sure that you have a 'CAT-5' or 'CAT-5E' cable, not a 'CAT-3' cable, which is much slower, over long distances.
Use another Ethernet cable from one of the (three? four?) 'LAN' ports on the Belkin to the network-port on your computer. Again, check that you have a "straight-through" cable, not a "cross-over" cable.
Turn the CLEAR modem off.
Turn the Belkin off.
Turn your computer off.
Turn the CLEAR modem on, and wait until its lamps settle-down to a consistent pattern.
Turn the Belkin on, and wait until its lamps settle-down to a consistent pattern.
Turn your computer on, and let it boot.
You now should have Internet access.
Note that the router "dynamically" shares the Internet connection.
If there are 4 'LAN' ports, then each of the LAN ports gets as much speed as it needs;
you do not have a 25/25/25/25 split, unlike cutting-up an apple-pie to feed 4 people.
Run a "speed-test" on your computer, and you should be getting as much speed as you are paying for. Having the Belkin in the "middle" of your network should *NOT* slow-down the speed-test at all.
Apr 04, 2011 | Belkin (F5D7230-4) Router (587009)
232 people viewed this tip
David Payne
David Payne
