Tip & How-To about Coffee Makers & Espresso Machines
Saeco, Gaggia, Spidem VENTILATE, Prime what is mean, how to perfrom
Ventilate or priming or else loading all means the filling the machine system full with water, like pump, piping and boiler. This must perform first time of starting up the machine.
It will also appear if the water system in not full of water especially after the steam preparation some steam can be blocked in the system and the machine recognized it by luck in the pressure.
Another reason that ventilate it appears on screen is because air have been insert and blocked in the water system usually from water filter or water softener located in water tank.
So here how you Ventilate or Priming or loading:
Place a container beneath the steam tube.
Turn the knob counter clockwise to start loading the circuit.
Wait until a steady stream of water flows out from the nozzle.
Turn the knob clockwise
to terminate the circuit loading process.
Remove the container. The machine is warming
up; lights are flashing.
Note: You must load the circuit before starting up
the machine for the first time, if it has been inoperative
for a lengthy period or if the water tank has
been completely emptied. The circuit must also be
loaded each time the light flashes
Coffee Makers & Espresso Machines Logo
IT SHOWS "VENTILATE" IN PRINCIPAL WINDOW. WHAT
Hi
That means the pump needs to be primed by running water through the wand. Push the water button and open the knob on the right. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water needed to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.bansheracer_15.jpgbansheracer_16.jpg
Jan 31, 2011 | Saeco V-spresso Espresso Machine
My Saeco Incanto Sirius machine keeps asking for yet another VENTILATE cycle
This means the water cannot flow through the machine. Normal fix is to prime the machine (turn water dispenser on, fill a cup) or descale the machine. Go through the menu, select descale, enter, then turn the steam knob fully anti-clockwise. You should put the descaling solution in the water tank first.
If you have the auto-descale in the menu then run it. Run the solution through the machine twice. Then rinse well.
Oct 03, 2008 | Saeco Vienna De Luxe Espresso Machine
My machine displays "Need to Prime". I attempt to prime it but the message keeps reappearing. In other words is seems that it is unable to be primed in the usual fashion. Any advise would be appreciated. Thanks
Ventilate message
That means the pump needs to be primed by running water through the wand. Push the water button and open the knob on the right. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds can get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message. One thing to remember is when you are working on the water system (have the water tank off) do not fill the bean hopper and visa versa. Keep them covered when working on the other. Cross contamination will damage a machine fast
Oct 22, 2010 | Starbucks Saeco Italia Digital Barista...
error message "Ventilate"
Hi
That means the pump needs to be primed by running water through the wand. Push the water button for water(the drop symbol) You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Ventilate
Mar 15, 2010 | Saeco Magic Comfort Plus Espresso Machine
3,232 people viewed this tip
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
