Tip & How-To about Computers & Internet
How to install a window in a non cd-driver laptop/netbook/noetebook
First of all,go to the site below 1)go to this site http://wintoflash.com/ 2)download wintoflash 3)Then insert the Window CD in a desktop pc that have CD drive. 4)install wintoflash on a desktop pc that have a cd driver 5)run wintoflash 6)insert a pendrive in the desktop pc. 7)use wintoflash to insert the window into the usb pendrive 8)remove the pendrive and insert it in the non cd-drive laptop/... 9)then change the boot configuration of the laptop....make the boot priority to pendrive {to enter bios press F2 or del key} 10)exit the bios saving the changes 11)your laptop will reboot and then follow the instruction
Computers & Internet Logo
can't access my old account
Step 1. Download the password cracking utility OPHCrack at the site below
http://ophcrack.sourceforge.net/download.php?type=livecd
Step 2: Burn the software to a CD
Step 3: Insert the CD into your CD drive
Step 4: Boot From CD (Learn How to boot from CD)
Step 5: The Software works you through the remaining steps.
Step 6: Recover your password!
Step 7: Enjoy...
May 01, 2011 | Computers & Internet
how can i reformat my asus eee pc1000h if it doesnt have a cd drive?
You can reformat your Asus eePC 100h notebook using an Ubuntu Live USB.Here is how to make one: 1. Download an Ubuntu ISO Disk image from www.ubuntu.com or a debian ISO image file from www.debian.com. 2. You can also use an existing Live CD to create an ISO Disk image with if you have a working PC around.Many free tools exist for creating disk images.I suggest Ashampoo Burning studio or CDBurnerXP.Search for them on google. 3.Get your hands on a working PC that has Windows XP/Vista/7 installed on it. 4. Download the UnetBootIn utility from http://unetbootin.sourceforge.net/unetbootin-windows-latest.exe. 5.The procedure for creating the Disk Image is as follows: (a)Requirements: 1 GB or larger USB drive, formatted as FAT32(most USB drives come formatted as FAT32 by default, but if you need to format it, on Windows, go to My Computer->right click your USB drive->format.
On Windows XP, you must be logged on as an administrator; on Windows Vista and above, you will be prompted for permissions via UAC.
On Windows, the UnetBootIN software looks like this:
Follow the guided prompts on the software to make your Live USB drive, and be careful to select the corrrect linux distribution on the window.
When done, safely remove the flashdrive from the PC and plug it in your Asus eeePC 100h notebook.
Boot up your notebook and press the F2 Key as the system starts up and select the USB flash drive as the first boot device(You can also do the same from the BIOS setup).
When you boot up with the Ubuntu Live USB, select "Try Ubuntu without installing" option to run the Live OS on RAM.
When the system boots up completely, go to System>Administration>Gparted and the Gparted Disk utilitty will run.
From the Gparted menu, select the appropriate partition you want to format or modify.
You can read more on Gparted here.
When you are done partitioning and formating your HDD as you desire, you can also install Windows XP/Vista/7 from a FlashDrive by following the instructions below:
1.Get your hands on a working PC with Windows XP/Vista/7 installed.
2.Download the WinToFlash utility from http://wintoflash.com/download/en/
3.Install the application on the PC.
4.Once you are done,insert a Windows XP CD in the PC's optical disk drive and follow the installation instructions from WinToFlash.
By default, the installation path for Windows XP files on the drive is DRIVE LETTER:/Windows/system32.
See the screenshot below for more details:
You can use the created bootable USB to install Windows XP on your notebook.
For more on WinToFlash, see this link:http://komku.blogspot.com/2009/09/wintoflash-guide-install-windows-xp.html
Have a great time ahead.
Jan 14, 2011 | ASUS Eee PC 1000H Laptop
how do I format my hardrive on my computer
Not sure what O/S you plan to use but if you are using window XP, it should have utility to format your hard disk from the CD.
Try below site... you might find useful information
http://etech.maiila.com/
Oct 10, 2008 | Compaq Computers & Internet
229 people viewed this tip
David Payne
David Payne
