Tip & How-To about Refrigerators
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
METHOD B
1. Remove the left and right hex-head screws
(one on each side) from the front corners
of the unit compartment
2. Remove the four hex-head screws (two on
each side) from the rear flanges of the unit
compartment cover. NOTE: You will need
a 24” hex-head socket extension with a
magnetic tip to remove these screws.
3. Lift the unit compartment cover up, and
pull it forward off the refrigerator.
REASSEMBLY NOTE: When you reinstall the
unit compartment cover, make sure that the
two unit compartment cover tabs slide under
the rear cover flange, as shown below. This will
provide the proper air flow.
KitchenAid, Whirlpool side by side refrigerator Component Location and removing cover
http://www.fixya.com/support/r5759997-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method A
http://www.fixya.com/support/r5760017-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator remove the main board assembly
Refrigerators Logo
how to remove dvd drive on aspire 5720
A) Remove the AC adapter (Charger) and Battery
B) Laptop closed turn it over, lay it down on a soft cloth on a table, Battery Bay Compartment AWAY from you.
C) The Thermal Cover is the largest cover on the bottom of the laptop. Goes from the right side to the middle, and very close to the Top and Bottom.
There are four Philips head screws to remove in the cover, before the cover can be removed.
1) Under the middle of the Battery Bay Compartment, and at the Top/Left corner of that rectangular vertical vent, in the Thermal Cover.
2) At the Bottom/Right corner of that vertical vent, in the Thermal Cover.
3) In-between the two horizontal vents, located at the Bottom of the Thermal Cover.
4) Straight above the screw removed in 3), is the last screw to remove. There is a round shaped vent, inside a square at the top right of the Thermal Cover. The screw to be removed is at this vent's Bottom/Left corner.
Once all the screws are removed, ease the Thermal Cover up from it's left side, (Middle of laptop), at an angle, then remove.
D) In the opening with the Thermal Cover removed, there is one Philips head screw to remove, then the ODD can be removed.
(Optical Disk Drive. The DVD drive)
This screw is located..............ack, ack,.......fzzzt.......ffffzzzt,......
Jun 02, 2012 | Acer Aspire 5720 Notebook
how do I remove and replace the cmos battery A135 toshiba
If you have idea about it ......but this link can help you ...in this.. check it.....http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
Please rate and vote if you found this one helpful
Thanks
Sanjay Kumar
Apr 25, 2011 | Computers & Internet
How do you take the seat off a 2006 Eliminator 125 to fit soft luggage?
My 2006 125 Eliminator just got a reupholstered seat. Remove hex bolt at the very rear of seat. Remove right side plastic cover over battery (open with key, pull off cover) .Remove plastic cover on left side (2 large phillips head screws.) Remove 2 stainless hex heads on each side of bike that hold chromed plastic sleeves under passenger part of seat (4 hex heads). Then remove 2 smaller black hex heads (one on each side) under point where tapered passenger part of seat begins. Slide seat toward rear of bike do disengage from metal lip that holds down the front.
Be sure to use metric hex wrenches. 15 minutes or less off or on.
good luck
ride easy
Oct 18, 2009 | 2006 kawasaki EL 125 Eliminator
697 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
