Tip & How-To about Refrigerators
KitchenAid, Whirlpool side by side refrigerator Component Location cover
Component Locations.
As you see the refrigerator on the top you can see the decorative panel.
Above refrigerator after you will remove the front decorative panel you will find the compressor on left side behind the inverter assembly and on right the Main control board assembly and behind it the condenser fan motor both secure inside silver aluminium boxes and located over the bigger box of the condenser.
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method A
http://www.fixya.com/support/r5760017-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
http://www.fixya.com/support/r5760029-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator remove the main control board assembly
http://www.fixya.com/support/r5760103-kitchenaid_whirlpool_side_side
Refrigerators Logo
I can't find the fan resistor on my 2004 Mazda 3. Can someone help? I took the glove box out but do not see it. Also, there are no good service manuals for the 2004 Mazda 3 online! Thank you, Joe
This is for the blower motor resistor 04 Mazda 3 2.0
RESISTOR REMOVAL/INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the two nuts securing the cooler hose (LO).
  3. Remove the following parts:
  1. Front doors
  2. Console
  3. Shift lever component.(MTX)
  4. Selector lever component (ATX)
  5. Decoration panel
  6. Front scuff plate
  7. Front side trim
  8. Glove compartment
  9. Shower ducts (LH, RH) (See A/C UNIT REMOVAL/INSTALLATION.)
  10. PASSENGER JUNCTION BOX (PJB)
  11. Car-navigation unit
  12. Lower panel
  13. Column cover
  14. Meter hood
  15. Instrument cluster
  16. Steering shaft (See STEERING WHEEL AND COLUMN REMOVAL/INSTALLATION.)
  17. A-pillar trim
  18. Center panel module
  19. LCD unit
  20. Windshield wiper arm and blade
  21. Cowl grille
  22. Cowl panel
  23. Windshield wiper motor
  1. Disconnect the air mix wire from the air mix link and wire clamp.
  2. Disconnect the airflow mode wire from the airflow mode main link and wire clamp.
  3. Disconnect the following connectors:
  • Blower motor connector
  • Evaporator temperature sensor connector
  • Air intake actuator connector
  • Resistor connector
  1. Remove the rear heat duct (1).
  2. Remove the heater case. (See A/C UNIT REMOVAL/INSTALLATION.)
  3. Remove the dashboard.
118941934
  1. Move the A/C unit to the right and remove the resistor.
CAUTION: While moving the A/C unit, do not apply excessive force. Otherwise it will result in deformation of the refrigerant piping or refrigerant gas leakage.
  1. Install in the reverse order of removal.
© 2015 ALLDATA LLC. All rights reserved. Terms and Conditions
Mar 10, 2015 | 2004 Mazda 3
leveling refrigerator with no shaft above wheels
use house shingles to level it,you want the front a little higher so the doors will close easier
May 28, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
need to remove decorative door panel
There are two main ways to remove it.
  • There should be screws on metal trim the side and or bottom of the dishwasher door. Take those out and it should come right off.
Or
  • There are screws on the back of the door screwed in to the front of the door. Remove the screws and it should come off.
Now this is say IF it was installed properly and not clued or screwed on by just anyone.
Good luck. I hope this helps.
May 30, 2010 | Bosch SHV68 Built-in Dishwasher
Amana SR520S with NO ice dispenser
1. Unscrew the philips screw at the top of the door handle and take off the cap.
2. Go to open the door and your knuckles will be touching a cover panel.
3. Release this cover panel to reveal the screws that hold the door.
4. Unscew the screws to release the door handle.
5. With the handle now off the decor panel can be removed by sliding it out.
Jun 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
782 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
