Tip & How-To about Microsoft Windows Media Player
Installing Windows Media Player 11 without validation.
Windows Media Player 11 is 24.5 MB in size, when u double click on it u will require net connection for it to install so that it can be validated.
But the trick is that u don't require net connection nor a
Microsoft Windows Media Player Logo
I am trying to load Kies software on my PC , when I load with Disc , message comes up " install.net framewirk 3.5. I have already installed this however the set up guide will not go ay further. it seems to be stuck on Drive E. I have also tried installing Kies from the Samsung website and a message also comes on with "you are not connected to the internet "I know I am connected to the internet so not sure why or what is going on . When I tried to connect with USB cable from phone to PC it asks about seraching for drivers on PC so I click for it to search however that too comes up zero with driver not found . Do I need to download driver ?? . I am from New Zealand
*Please check if your mobile device is supported by Kies before download.
http://www.samsungapps.com/about/onPc.as (Not all Samsung Phones are support)
System Requirements to install Kries
System requirements Description
OS: Windows XP(service pack2), Windows Vista, Windows 7
CPU: IntelĀ® Pentium 1.8 GHz processor or higher (recommended)
Minimum memory (RAM): size 1.00 GB (recommended)
Free hard drive space: At least 500 MB
Screen resolution: 1024 X 768 (600), 32 bit or above
Required software: Net Framework 3.5 SP1*
Windows Media Player 10 or later
ActiveSync(Windows XP), Device Center (Windows Vista)
DirectX 9.0C
Since you have not mention your PC OS, try updating your system files via Microsoft Update & reinstall Kries.
Hope it helps.
May 07, 2011 | Computers & Internet
while i copying songs my Samsung yp-u2 512 Mb player not showing any thing,what hapend to it
it like your samsung media player is invected by virus that make your file hidden
for problem like this i usually use smadav antivirus to scan it
you can download smadav antivirus at http://smadav.net
after download smadav antivirus connect your media player to computer, then double click smadav antivirus, check all drive at you computer include your media player, then click scan
wait until scan finish, after finish click fix all, and your file will back again
i hope this helpful
thank you for using fixya
Feb 15, 2011 | Samsung YP-U2X Digital Media Player
validate windows
Pretty easy.
Do you have winzip?
If not download this software.
now right click on the wmp11 setup and choose winzip>extract to..>choose a directory and
click ok/extract.
Now go to that directory and you get many setups there.Run each one except the one that shows the validation message.Don't reboot your system until you have installed all the setups.If in case that happens then run the remaining setups after the reboot.Once all the setups are installed reboot your  computer.wmp11 is now installed.Enjoy!
p.s.:If any of the setup doesn't run, leave it.
Nov 08, 2008 | Philips GOGEAR SA6045 MP3 Player
WMP 11 validation issue
Windows Media Player is a feature of the Windows operating system and cannot be removed entirely. However, depending upon which version of the Player and Windows that you are using, you might be able to roll back to the version of the Player that was previously on your computer. The procedure varies depending upon which version of the Player you are running.
If your computer is running Windows XP Service Pack 1 (SP1), Windows XP SP2, Windows 2000 SP3, or Windows 2000 SP4, you can use the Set Program and Access Defaults feature to remove links to the Player on your computer. Note that this does not remove the Windows Media Player software. To remove access to the Player, do the following: 1.
In Control Panel, double-click Add or Remove Programs.
2.
Click the Set Program and Access Defaults button, and then choose a configuration (such as "Non-Microsoft" or "Custom").
Mar 02, 2008 | Computers & Internet
I still can't format please help me!
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Sep 26, 2006 | iLO (2 GB) MP3 Player
1,117 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
