Tip & How-To about First Alert PIR720R 360 Hands-Free Light Socket with Motion Sensor
Do not
Never touch a light socket when its plugged in you will get shocked
First Alert PIR720R 360  Hands-Free Light Socket with Motion Sensor Logo
cigarette lighter does not work fuse is good how do I find the relay
are you useing the lighter as a lighter or pluging in an acc.. heavy smokers wear out the element 1rst. try testing the socket with a test light. touch the stud inside the socket, the back part with the tester, do not touch the side or you will blow the fuse, touch the edge of the socket with the tester ground clip. if the test light lights up, wiring is good and element is burnt inside, you need new. if acc. is plugged in sometimes prongs in socket will bend out of place, use a popcicle stick to rebend. Kirk fc6fc
Apr 17, 2011 | Volvo S40 Cars & Trucks
TV will not come on
first please check the socket of your AC cord and try another electronic device on the same socket, IF it is not turning on.then there is no problem in your television and if it is turning on then please check the AC CORD of your television if the problem persist call the technician becouse if you touch the plugged television cord it may result of electric shock...So i request to call the technician
Oct 30, 2010 | iLO 2600 Television
Kegerator is shocking me
YOU NEED TO BUY A ADAPTER FROM 3 TO 2 AND HAVE AND BE SHUR THE WIRES ARE NOT REVERS YOU HAVE A SMALL AND A LAREGE OPENING IN THE PLUG AND THE SMALL IS THE HOT WIRE IF THE ARE REVERS IT WILL SHOCK YOU ADD A GROUN GROM THE COLD WATER LINE TO THE REF. ANY SCRUE IN THE BACK. AND BE SAVE USE GOOD NON SCHOKING BOOTS.
Jan 22, 2009 | Refrigerators
get shock when touch door on a turbo air
wall plug could be wired in reverse cause the ground to feed the refrig have you checked it? if not you can buy a circiut tester that plugs in socket and it will tell you if its wired right get it at Lowes for about 5:00 if it was a dead short it would should kick the breaker
Sep 17, 2008 | Refrigerators
replace the plug socket on gateway m520
plug socket? power socket? you must have alot of experience to replace the power supplies socket or you can just replace the power supply itself... as opening the power supply and touching one of the capacitors can give you a hell of a shock.
Jul 02, 2008 | Computers & Internet
748 people viewed this tip
Top First Alert Home Security Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
woodzowl307
Justin Bonnema
Level 1 Expert
Are you a First Alert Home Security Expert? Answer questions, earn points and help others
