Tip & How-To about Cameras
Lens adapters beware!!..
I just purchase a new camcorder (sony Hd1000u) and order a lens kit with adapters for it, but not everybody has experience to how to install them.. Well.., it just about a bit of common sense. First be sure to know what size of lens your camera will use in my case I need to adapt my new 72mm tele-photo lens to my Sony 37mm. usually when you buy a lens kit they come with different adapters. I use a 37-58mm adapter for my camcorder. but be carefull, make sure that the adapter be place first in the lens to be use, in my case to my 72mm lens. Screw it carefully soft tight then screw in the lens of your camera. Do not ever screw the adapter first to your camcorder lens or you will encounter a big problem when you want to remove it later. Make sure you clean your lens before installing with proper lens cloth & solution. This tip will apply to just any camera with interchangeble lens system.
Cameras Logo
How to fix Sony HVR-HD1000U camcorder if it is not charging
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Dec 01, 2015 | Sony HVR-HD1000U Camcorder
why is my sony hvr hd camcoder not switching on
hi,
I have a sony hvr-hd1000u - I am getting an error message that says reinsert the cassette. Please let me know what you think the issue is. My camera will not work now because of this message. The cassette is stuck in the camera and won't come out.
Hello.
This problem is solved by replacing the cassette complet mechanism, part number A1437006A MD (N220) SUB ASSY (S) A
... the cause: the flex is broken.
you can buy it on this website: https://www.servicesplus.sel.sony.com/sony-part-number-A1437006A.aspx
Hollmann.
serviciotecnico@videosistemas.com
Nov 27, 2010 | Sony HVR-HD1000U Camcorder
the camcorders show no picture and keeps flashing lens cap but the lens cap is not on?
Download service manual and diognose problem its easy like ABC you might need a new CCD or another part has failed and has to be replaced just order part online its posted to you and fix it your self school stuff easy peezy this is how everybody does it it will say on service page why the camera has no image and flashes on screen messedges you can always put it on ebay hey dont forget to throw in service manual as well
Jan 31, 2010 | JVC GR-D32 Mini DV Digital Camcorder
6,384 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
