Tip & How-To about Televison & Video
HOW TO START YOUR TV WHEN IT WILL NOT START
We have a Samsung tv and our signal comes through ADSL via a router to the tv and the laptops in the home.
It happens that the tv does not want to start. The remedies I use for that is what I have learned from my service providers.
Start by disconnecting the tv,router from the electrisitity for a couple of minutes then try again, if the picture of the young lady appears on the screen and tells you to click on the remote for the picture to appear.
If that does not work I disconnect all cables from electricity and turn the router off. Connect all cables again and find your station.
If nothing happens now than I start being irritated, and push the"source" button on the remote and reassure me that all cables are soundly in their place, he scart-plugs and all other plugs as well. And almost every time after this treatment the tv starts. It takes a lot of patience and thinking, but most often it works. (((-:
Televison & Video Logo
internet light on router diplayed red
The ADSL installation details have changed, so you need to update the router.
Check the router has not been moved too far from the laptop.
Jan 27, 2014 | NetGear DG834G Router
instructions on how to connect my laptop to my adsl modem wirelessly.i have a 5200g billion router which is connected to my router via ethernet cable.i have a lenovo laptop with bluetooth.
Billion's BiPAC 5200G R4 is an economical ADSL2+ Firewall Router with 802.11g Wireless AP ideally designed for home and SOHO users to enjoy rich firewall security, mobility, and faster speed when using ADSL Internet connection.enabling system administrators to easily fit this security router into existing network environment and manage the IP assignment without reconfiguring your laptop with wifi.
Jul 13, 2011 | Computers & Internet
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
Several Router problems
It sounds like an ADSL signal strength issue. Test that it is not a problem with the ADSL phone cable setup, using the shortest ADSL/Phone cable you can find (under 1Meter is best)unplug all other phone line using devices and filters from the wall jack points and test the routers connection again as the only device plugged in(this is Isolation testing) If the issue replicates itself under isolation testing conditions then ring your ISP providor and request that the "ADSL signal voltage" needs to be increased slightly as your router is not hearing the ADSL signal properly. If the issue doesn't replicate itself under isolation test conditions, you are either using an old or bad ADSL/Phone cable or your cable is too long (should not be longer than 5meters)or if you are using a wall socket/splitter for direct adsl access (without filters)then test the socket with a filter to verify the socket/splitter is not the cause of the problem, if you do use phone filters, during isolation testing, test each of the filters individualy with the router and see if the disconnection issue is replicated if so replace the bad filter the disconnection issue was being caused by phone signal interferance. Your third request requires you to setup the LAN info on the windows side of your connection not the wireless card, this can be verified by searching for websites via thier IP address which will work, when searching via their website name wont, DNS resolution issue, it is probably best practice to use MAC Addressing for your wireless setup though.
May 15, 2007 | Trendware TEW-452BRP Wireless Router...
380 people viewed this tip
Top Televison & Video Experts
