Tip & How-To about RIM BlackBerry? Tour 9630 Smartphone
BlackBerry Tour: How to find your IP address
Like most devices that connect to a network or to the Internet, your BlackBerry Tour has its own IP address. If you need to find your IP address (or if you're just curious) follow the steps below. (The process may vary for other BlackBerry models, but it should be similar.)
A. From the main screen, press the BlackBerry button (the one with seven dots) to go to your Home folder.
B. Find the Options folder (with the wrench icon) and select it.
C. In the list of options, scroll down to Mobile Network and click the trackball.
D. Press the BlackBerry button.
E. Click on Tools on the menu.
F. Click on Ping.
When the Ping test utility opens, you'll see your IP address displayed at the top of the screen, labeled "Device IP." You don't have to use the Ping utility; you can click the back arrow to exit out after noting your IP address.
Alternatively, you can run the Diagnostics Test, which will also display your IP address. To run the Diagnostics Test, follow the steps above, but after step D, substitute the following procedure:
E. Select Diagnostics Test from the menu.
F. Press the BlackBerry button.
G. Select Run.
The Diagnostics Test can take a few minutes to complete, and it will display various settings for your BlackBerry, including the IP address (Device IP). The report generated by the Diagnostics Test will be saved so you can view it later for reference or use it to compare current settings.
RIM BlackBerry? Tour 9630 Smartphone Logo
What is an IP address
IP address is like our normal address. if you have to go somewhere you need to know the address. Same goes for devices. IP address is given to all devices which are connected to a network. So that they can understand from which device you have to connect.
Now to get you laptop's IP address just type "what's my IP address" in Google search bar.
Jun 04, 2017 | Computers & Internet
just downloaded an app to my nokia lumia 920 (JMPS mPrint) to use it they are asking for my IP address what is it and where will I find it please
An Internet Protocol Address is the "address" your device uses when it connects to a network that identifies it when communicating with other devices. If you need your internal IP (the IP used for your local network) you can usually find it in the network settings of your device. If you need your external (internet) IP address you can find it by typing "whats my IP" into google
Aug 04, 2013 | Nokia Lumia 920
how to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
no ip address
Network Card's driver is not installed. Check and install drivers from Device Manager Window.
IP Address can be assigned automatically(through APIPA/DHCP) or Manually.
Automatic:
There is no DHCP server, it takes the Automatic Private IP address(APIPA) or else get it from DHCP server by using "ipconfig" command
Steps: Start>accessories>command prompt>ipconfig /renew
Manually:
Right click on My Network Places> Properties>Right click on Local Area connection>Properties>General Tab>select Internet Protocol(TCP/IP)> Properties>General> select "Use the following IP address> assign IP, Subnet Mask, Gateway and DNS> Press OK Tab.
Dec 10, 2009 | Dell Dimension 3000 PC Desktop
1,410 people viewed this tip
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
