Tip & How-To about Dryers
Most overlooked dryer energy savingr problem ever!
First, you must know that a common clothes dryer is really a water pump. It pumps water outside by
heat convection. Just because its hot doesn't mean its drying clothes efficiently.
The tip here concerns the filter. If you think your filter is clean, look again. You may have cleaned
all lint from it but it probably is still ineffective and energy draining.
Do this. Place your filter under a trickle of water in the sink, after lint removal as you usually do.
The water, most likely, will not go through the filter. What happens is that water promotes scale and clogs
the filter. (well you've got water being dried by heat which leaves scale.) This scale (or stopped up filter)
can cause a great deal of extra running time, and a dryer uses a lot of energy. (Electricity)
Scrub the filter with a bristle brush and dishwashing liquid and then run water on the filter again.
You can see how much more the water runs freely through the dryer filter.
Dry the filter, and reinstall. It's so nice to save a great deal of electricity!
You can see how the wet air is not moving the water out of your clothes very efficiently and it also
can cause the dryer to overheat too much so that the thermal switch (or fuse) blows thus causing a
expensive service call. (Most won't even tell you about the scale clogged filter anyway) Because most
don't know it either.
Enjoy your savings!!!!
imufo2
Leo Ponder
imufo2@sbcglobal.net
Dryers Logo
takes to long to dry clothes
after checking and replacing the vent going outside still the air was not venting and inside my drier everything was wet although the air was hot. After removing the rear panel i saw the blower belt disconnected. it took me some time to get the belt on but everything is ok and the air is venting and clothes getting dried. Also note that the little pulley came off its positio too.
Feb 14, 2013 | Whirlpool Dryers
03 civic heat doesn't work unless driving
no that is a water pump or a stuck thermostat. see when you are driving the coolant is going through the system which means the faster you go the faster the water pump goes and more pressure on the thermostat. you have a stuck thermostat
Dec 14, 2012 | 2003 Honda Civic
no heat
Hi, Sounds like the coils on the top of the gas valve are not opening after they get hot. This is a very common problem with a gas dryer. How clean is the vent that goes outside?
Let me know ifI can help further.
Thanks
Vic
May 11, 2009 | Dryers
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
922 people viewed this tip
Top Dryers Experts
