Tip & How-To about Computers & Internet
How to use 2 internet connections at once
Open the "Network and Dial-up Connections" folder of your computer.
Right-click on the local area connection that is to be modified and select "Properties."
Select "Internet Protocols" and choose "Properties."
Select "Advance."
Type "2" in the "Adapter Metric" box.
Click the gateway address in the "Default Gateways" box and select the option "Edit."
Type "2" and click "OK."
Click "OK."
Computers & Internet Logo
local area connection is disabled
Hi, open your Computer and follow the Instruction-
For XP
  • Open Control Panel and select Network Connection
  • Open Network connection
  • Right Click on Local Area Connection, show as Two Pc and select Enable/Disable
For Vista
  • Click on Start
  • Then Control Panel
  • Then Network and Sharing Center
  • Manage Network Connections. Right click on the Icon and select Enable.
  • Most HP
May 17, 2011 | Computers & Internet
Internet Won't Connect
Press Start->Connect To -->Show all connections.
If the Local Area Connection icon is crossed with a red X, right click it and choose (Enable, or Repair).
If there is no Local Area Connection icon, you must create a connection.
In the left panel in Network Connection window click create new connection.
1.The wizard pops up
2.Click Next.
3.Put a (dot)mark in Connect to the Internet .
4.Click Next
5.Choose Set up my connection manually
6.Click Next Choose the type of connection you have with you ISPN (dial up, etc.)
7. Click Next , and follow the instruction from here.
Hope it helps you find your way to a solution
Aug 30, 2009 | E-Machines Computers & Internet
150 people viewed this tip
David Payne
David Payne
