Tip & How-To about Office Equipment & Supplies
Get rid of the line in your faxes or copies from your copy machine
If you are getting one of those black lines in your copies from the copy machine/fax machine, it may not need a new drum.
Most likely the scanning glass is dirty if the line appears from copies that are fed through a feeder, clean the little glass strip area (usually to the left) just before the scanning area where you manually place a paper to be copied. In most cases there is a spec of something on that glass. Don't scrap it with anything abrasive because if you scratch the glass you will have a line that will never go away. In most cases a damp klenex, paper towel or soft cloth with water will work. For stubborn specs dampen your klenex, paper towel or cloth with a little rubbing alcohol. This will also work well for getting rid of any greasy smudges on the glass strip and the larger glass area on the copy machine. Most of the thime the spec is from liquid paper or white out.
If you are getting calls from people you send faxes to saying your copies have a line on it and you use a dedicated 'fax machine only', look for the glass strip and clean it as directed above. If you are receiving faxes with a line, call the sender and give them the above tip.
If this tip works, it sure beats paying for a new drum you don't need.
when making a copy on the fax machine, it has a la...
your must clean scan unit ,mirrors and check drum .make a white copy if the problem occurs change drum unit
May 20, 2010 | Brother IntelliFAX 4100 Laser Fax
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Hello, I have a little used 18 mth old Sharp FO P610 fax machine. It receives fine but when sending the recipient receives 'black all over' pages. I have tried disconnecting the unit for an hour and then reconnecting. No change. I recently changed the film but have checked and the new film installation seems correct. Would apprechiate your ideas. Rod Auckland New Zealand
Try just making a copy and see if you have the black lines on your copy (most fax machines have a basic copy function if it is you have dirty scan glass and on these small machines it is a real hassle to get too and clean Try Canned Air. If no black line on your copy it may be the recipients machine.
Aug 12, 2008 | Sharp Office Equipment & Supplies
Copy Quality
The CIS scanner has one of the LCD bits bad. If it is new, claim a warranty repair. Otherwise, strip the scanner out and go over all the solder joints
Feb 27, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
169 people viewed this tip
jasbo
jasbo
