Tip & How-To about Televison & Video
How to detect a defective remote control?
Kindly use a digital camera.put it in front of television remote control while freezing the bottoms anywhere.A good condition shows the LED sensor flash" while freezing it.A defective remote control indicates no flashing of LED.
this is very simple.
this video shows an ok remote control''
Televison & Video Logo
i cant turn tv on with remote
Maybe the problem is in the remote. To check the remote use a cellphone camera or maybe a digital camera will do. Just focus the camera on the remote LED it is located on the top of your remote, while pressing the buttons of your remote put the camera on the LED if the remote is good you will see a blinking lights on the camera while pressing the buttons of the remote. If the light doesn't show try to replace the LED on your remote or maybe just clean it also clean the button panel with a pencil eraser, Usually the remote control is the problem, Hope this may help you if the problem still exist just email me...
Aug 14, 2011 | Toshiba 57H81 57" Rear Projection...
3 yr old KDL-40V3000. Remote suddenly stopped working. Changed batteries twice - didn't make any differnence. Then noticed no LEDs lit on TV front pane! But TV is powered on. Also TV can be operated fine from local button on top panel. Could it be a remote sensor/board problem? Is this something I can fix myself?
U have a Digital Camera turn it on,take ur tv remote pushes all the remote buttons on the front of the Digital Camera.One by one buttons.If all buttons of the tv remote work will register on the Camera viewing screen,because the Digital Camera able to read infer red signal output.Will figure out wright away the tv remote work or not easily.Tv remote sensor/board have no LED power light lite up might just be a lose connection or just a dead LED lamp only,because all the buttons on the remote sensor/board to the tv panel work wright?Try website Remotes.com to buy tv original remote.
Jun 10, 2011 | Sony BRAVIA KDL-40V3000 Television
my samsung led remote control has just stopped working and i can't get it to work again. I've changed the batteries and i cannot find the reset button. I've unplugged the power from the wall and still no luck. plz help
We need to find out first if the remote is putting out the IR signals or not, or the problem is in the TV IR receiver module.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
EBAY. AMAZON
Mar 12, 2011 | Samsung Bn59-01041a Remote Control
The ML-L3! The laser light does not come on. I tested the battery. It is good.
How do you know it's not coming on? The LED (not a laser) puts out infrared, normally not visible to the human eye. If you have a point&shoot digital camera or a dSLR with LiveView, try taking a photo of it and see whether it lights up when you press the button. It'll probably show up white. You might try a TV remote for comparison.
Also, try cleaning both the LED window on the remote and the remote sensor on the camera. And make sure you're pointing the remote at the sensor.
Dec 26, 2010 | Nikon ML-L3 Remote Control
remote control not working
It could be either remote is bad or remote sensor located at tv front is not working.
You can test remote with help of any digital camera, watch remote front through camera and press few buttons on remote, you will see infra red led blinking at remote front, that means remote is good and working. Remote sensor in tv is defective and need to be replaced by qualified tech.
If infra red led of remote does not blink pressing any button while watching through digital camera then problem is remote, buy new one to solve the issue.
Thanks.
May 05, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
1,299 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
