Tip & How-To about Office Equipment & Supplies
How to clean a Clogged/Blocked Print Head/Cartridge..
If you fault is according to user manual, a defective Print Head/Cartridge... The Print Head/Cartridge., maybe so clogged, and clogged up so deep that can not be cleaned in the normal way. Then, the printer can not communicate with the computer at this point. So you can't send the cleaning command to printer.
Here's what to do:
1. remove all the Print Head(s)/Cartridge(s).
2. Take out the Print Head/Cartridge. by releasing the lock lever. Look in the "Easy Setup Instruction" Step to find the location. Obtain a manual. (You can download it from manufacturers web site)
3. Put the Print Head/Cartridge. in a plastic zip lock bag. (Test the bag is air tight.)
4. Soak the covered Print Head/Cartridge. in hot water (hottest setting of the tap) for 5 minutes. The high temperature will soften up the clogged ink.
5. Immediately install thePrint Head/Cartridge. (Must be be dry) in the printer, and install all the ink cartridges.
6. Turn on the printer. If this works, you should not have a working printer, Now then, Most Important. Start the cleaning process from the computer. Run the cleaning several times to deep clean it.
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
My Canon won't clean its print heads
Have you tried power cycling the printer?
Feb 17, 2008 | Canon i860 InkJet Photo Printer
i960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
My Canon Pixma will not print yellow or cyan on my mac?
In your user manual, look for cleaning process. Your printhead is probably clogged, and that is why yellow or cyan wont print. You must go trough process of cleaning or deep cleaning in your printer software preferences.
Im not sure for exact procedure on MAC but it should be something like this: go to system control panel, find there your printer and open it's preferences, there should be something like maintenance mode, and from there you should find cleaning or deep cleaning buttons.
If you cant figure it out, search for user manual online, Cannon has good user support and im 99% sure you will find out user manual for your printer. In user manual there is written exact procedure for cleaning your print heads.
Also make sure that your cartridges are not empty maybe?
Mar 06, 2011 | Canon PIXMA iP1000
inkhead clogged. Have tried deep cleaning several times. Cyan just won't print even though it is a new cartridge
Inkjet printers do not like being left unused.
The print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 14, 2010 | Lexmark Prospect Pro205 Wireless...
372 people viewed this tip
k24674
jasbo
jasbo
