Tip & How-To about Washing Machines
How to avoid clogging of washing machine water drill?
Washing machine is very useful to us especially at home...it needs an extra care.After using this kind of unit.always check the hose to avoid clogging,
Washing Machines Logo
My Hoover 750 washing machine does not spin any more. What would cause that and can I fix it with a new part?
Hello.
The answer to your question is YES.
And below is the instruction on how to solve the problem.
The Hoover750 is a washing machine that offers many standard features and a few additional options, including energy saving cycles, variable spin and water pressure options and pre-wash, extra rinse and timer features. Available online and in select appliance, department or home retail stores, the Hoover washing machine should function well with basic maintenance and care. However, if individuals experience problems with the machine, some troubleshooting steps may be beneficial in locating the source of the issue and a potential resolution.
1. Ensure the Hoover washing machine is firmly connected to a grounded power supply if the machine is not working. Reset the circuit breaker if necessary.
2 Turn the main power switch to "On" and open and close the washer door firmly if the electrical outlet has power but the washer is not functioning. The washer will not operate if not turned on or if the door is open.
3 Verify the water inlet hoses are connected firmly and are turned on if there is no water flowing to the washing machine. Straighten out any kinks in the hoses and remove possible obstructions from the inlet screen.
4 Straighten the drain hose if the water is not draining from the unit. Remove any possible blockages from the drain hose. Tighten the hose if necessary.
5 Avoid selecting a "No Spin" option if the washer is not spinning water out of the drum. Choose a new spin cycle and press "Start" to remove water from the drum.
6 Verify that all four feet are touching the ground evenly if the washing machine is rocking or vibrating during use. Adjust as needed.
Thanks.
Feb 19, 2011 | Hoover Washing Machines
Lint Filter
madams50 I have yet to see a lint filter on a washer. However the factories are always doing something new. What brand and model machine do you have. Alot of the Care and Use manuals are here at Fix Ya.
Aug 10, 2008 | Washing Machines
hooking my washing machine to the kitchen faucet
See that your hose does not have any clogging in the filter screens; connect to the cold. careful with the threadings; turn on faucet & check for any leaks........start washing. Will tell you later how to get a manual. Regarding hot water, your machine can heat it if it has provision.
Dec 19, 2007 | Washing Machines
My washing doesn't smell clean? Help
the drain water pump its not working properly , needs to be cleaned the drain hose needs to be check for posible bent or clogged , ,please be sure that the drain hose ,and drain pipe are installed ,no more than 12 inches above .of the machine, and avoid long hoses. let me know thanks
Jun 20, 2007 | Whirlpool AWM5145/2 Front Load Washer
126 people viewed this tip
Top Washing Machines Experts
