Tip & How-To about Televison & Video
DVD not reading problem solved
Often DVD problem needs reset, which will overcome power line glitches. Remove from power line for five minutes Then power on. This can solve 90% of the problem. DVD has more capacity for data and the tracks are finer, so the lens had to be clean. Use rubbing alcohol and cotton can remove smoke or oil vapor. Same on the track of the lens assembly. Then us cd or vcd to work the dvd player so it will run the mechanism smoothly. After a while of testing, you can start using your dvds.
Cleaning laser lens has to be gentle and only damp cotton. Touch gently with cotton so the lens mechanism is not damaged. Otherwise you have to replace the whole DVD. TDK lens cleaner dry method also works but will not damage your laser lens mechanism.
Televison & Video Logo
Run then stop after five minute
Check the reset/off circuit breaker. If the circuit breaker has tripped, wait for five minutes and then press the switch to the reset button.
You want the switch to be on reset, make sure that the power cord is plugged in. If the power cord is plugged in, unplug it, wait for five minutes, and then plug it back in.
Remove the key from the console, reinsert the key into the console.
These are just a few basic steps and if it does not solve the problem please do not hesitate to get in touch with our Technical Support Team by chat at www.sportsmith.net or by phone at 888-713-2880 we would be happy to help you further solve the issue. Hope this helps and we look forward to hearing from you :)
Aug 11, 2015 | Nordic Track Exercise & Fitness
dvds and cds don't work. the screen just says reading to no end
First remove power cord from the wall for five minutes o reset the firmware. Then power on again and let the firmware load before inserting any dvd or cd. If it still can not read the disks, you use TDK lens cleaner until it can read the cleaner disk. It maybe power line glitches, you may need powerline filters for this dvd player.
Aug 20, 2010 | Yamaha DVR-S150 DVD Player
DVD PLAYER IS NOT WORK VHS IS WORK
DVD players are now more dust sensitive due to the fact tracks are finer than cd. So TDK lens cleaner may help to read DVDs. Use it often? Some problem came from firmware corrupted by power line glitches(zapsor surges), Remove power cord from wall for at least 5 minutes, to reset the computer memory in your combo. Then turn it on again. Defective semiconductors can be room temperature annealed by turn on the power but do not run any disks or cassettes for a week. Then try the DVD. After all that and no success then you need to replace the dvd or the computer board or the power supply board, in your combo.
Aug 15, 2010 | Samsung DVD-V4600 DVD Player/VCR
oven door won't open on frigidaire electric range ES200/300
Turn the power off at the breaker box for five minutes.
this will reset the system of any electronic glitches.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 01, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
6,720 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
