Tip & How-To about Microsoft Zune JS8-00001 Digital Media Player
How to unfreeze Zune....
If the Zune ever freezes, press the back button, and the up button on the control panel.
Microsoft Zune JS8-00001 Digital Media Player Logo
My Zune will not sync, Zune software says no zune connected....but it is
this is what you do
take off the usb
go to control panel
uninstall zune software
reinstall
put back in zune usb
should be working :(
OR press the back button on the zune and the down part of the black button it should reset then try again
Aug 30, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
zune lock
Zune lock is the switch at the top of the zune correct? Slide it into unlock position.
If it's passworded and you can't get it unlocked
try this:
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
If this helps Rate this a FIX-YA.
Jan 04, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Dropped zune freezng up
Press the back button and control panel up at the same time, or send it to get it fixed.
Mar 04, 2008 | Microsoft Zune JS8-00001 Digital Media...
zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
1,131 people viewed this tip
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
