Tip & How-To about Jura Capresso Impressa F9 Espresso Machine
Jura Capresso Impressa F9 'malfunction 8' fit without dismantle
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. The mechanism for dumping grounds becomes stuck from coffee grounds not properly waste out. This is usually cured by disassembling, cleaning all the coffee remains behind group, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
Also some coffee might be on the opt sensor that senses the up/down position of the brewing unit which when it's switched on the mechanism is not synchronizing and it will go all up or all down and show Malfunction 8.
Here is how to fix it without completely dismantle the machine:
Unplug, remove the water tank, pull out the bucket and tray, and allow to cool if necessary. Now - smaller fingers are better - reach into the machine, palm up. Feel as far back as you can, then work your way forward, toward yourself.
As you move toward you will feel a flat area about an inch wide (measuring front to back). Just back of this (away from yourself), you'll feel a crack about 3/8" to 1/2" wide. Push your fingers up into this area and feel around. You will probably feel stuff that feels like light, chunky rocks these are dry “coffee ground”. Break these up and they should fall out.
Again, small fingers are better and if yours are not once you got an idea of what you are doing, you can described it to someone with small ones and can do it. There is a tendency to not feel far enough back in the machine, so be sure to find the flat place at the lowest point of the mechanism then go just past it and up to find the crack.
Pulled out all compressed coffee “coffee grounds” you can fill. You can also get about a foot of plumber's tape (the metal stuff with holes in it that's useful for just about everything) bent it with a 4" radius, and worked it up into the crack to break up any stuff you couldn't reach. Work at this until no more stuff is in there. Now, tilt the machine toward you and "pat" firmly all over to jog anything left into the crack area, and check for chucks again. You can use a vacuum cleaner with slim tube so you can remove as much as possible with it also.
When that's done, put everything back together, move the machine to where you can work from the top. Don't start it up. Get a flashlight and the vacuum cleaner with the slim tube. Open the top "pre-ground" door and S**K everything out.
Now start up the machine, watch how the mechanism works, now, and try to brew some coffee. While it's actually squeezing out the coffee, tap some more on the "closed" mechanism to free up any more stuck coffee. Do this whole procedure 3-4 times to be sure, I suggest don't drink any of the first coffee it brews. Anyway, the machine should run good as new.
Good luck and please comment as to whether it works for you and vote for it.
Jura Capresso Impressa F9 Espresso Machine Logo
jura impressa f9 malfunction 8 i need help whats that
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffeegrounds inside the brewunit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
If it doesen`t, i could be that the o-rings inside the brew unit is defective and needs to be changed.
Jul 08, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
My F9 displays Malfunction 8
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and food grade lubricant for doing this. (I have only been able to buy parts from Europe online) One could by a new brew unit off of e-bay and change out the whole thing. But a simple cleaning or rebuild will typically suffice. One note. The cleaning tablets tend to strip the lubricant from the inside of the brew unit over time. Ocassionaly the seals in the brew unit will fall apart and bind up the unit. Either of these is usually accompanied by a sound of the brew unit motor straining to cycle the machine. If you are not savy in repairing it you may want to send it in. I suspect they will tell you it needs a new brew unit aand quote about $300 USD for the repair. About two hours, much patience, and about $10 in parts is most likely all it may need.
Mike
Jul 04, 2009 | Jura Capresso Impressa F9 Espresso Machine
franke saphira malfunction 8 help What is this?
Malfunction 8 is mother board failed, you will have to take it to franke uk
Apr 16, 2009 | Franke Saphira Espresso & Coffee Maker
Malfunction 8
I just fixed it. I saw some info from a Doctor in Hawaii who described reaching up inside the machine with some success and this inspired me (Thanks!). I had been getting Malfunction 8 for some time, and letting the machine cool (turning it off) for 15 minutes was the only way to not get the error. It always sounded like it was "straining" to make coffee. It would generally try 3 times to clear itself before the Malfunction 8, I'm sure those with the problem will recognize the symptoms. All the rinse/ decalcify/on/off stuff was temporary. We lived with this for 5 months or so. Finally, it would only get a Malfunction 8, and so became unusable, and we were considering sending it in for repair. This was the second round of Malfunction 8 problems; the first seemed to fix itself for an unknown reason. On to the fix: Unplug, remove the water tank, pull out the bucket and tray, and allow to cool if necessary. Now - smaller fingers are better - reach into the machine, palm up. Feel as far back as you can, then work your way forward, toward yourself. As you move toward you will feel a flat area about an inch wide (measuring front to back). Just back of this (away from yourself), you'll feel a crack about 3/8" to 1/2" wide. Push your fingers up into this area and feel around. You will probably feel stuff that feels like light, chunky rocks. Break these up and they should fall out. Again, small fingers are better and once I got an idea of what I was doing, I described it to my wife and she did it. There is a tendency to not feel far enough back in the machine, so be sure to find the flat place at the lowest point of the mechanism then go just past it and up to find the crack. Pulled out about five crusty chunks of burned, almost charcoal like compressed coffee. I also got about a foot of plumber's tape (the metal stuff with holes in it that's useful for just about everything) bent it with a 4" radius, and worked it up into the crack to break up any stuff we couldn't reach. Work at this until no more stuff is in there. Now, tilt the machine toward you and "pat" firmly all over to jog anything left into the crack area, and check for chuncks again. When that's done, put everything back together, move the machine to where you can work from the top. Don't start it up. Get a flashlight and a wooden spoon. Open the top "pre-ground" door and peer in. With the wooden spoon handle, poke in there and tap everything to break up any stuck things. I thought a shopvac with a small tube might work here, too, but wasn't sure whether something bad might happen. Anyway, tap tap tap about 100 times. Now start up the machine. Keep peering in; watch how the mechanism works, and don't trap the spoon handle! Now, try to brew some coffee. While it's actually squeezing out the coffee, tap some more on the "closed" mechanism to free up any more stuck coffee. Do this whole procedure 3-4 times to be sure, but don't drink any of the coffee it brews: The first ejected puck looked really aweful - it looked like about 1/3 moldy coffee; of course the machine had been sitting for 3 weeks, probably stuck in the middle of a puck ejection cycle. Anyway, the machine should run good as new. Good luck and please comment as to whether it works for you. - Woody
Aug 25, 2008 | Jura Capresso Impressa F9 Espresso Machine
Jura impressa E75.message mafunction 8 shows up
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and lubricant for doing this. One could by a new brew unit off of e-bay and change out the whole thing. But a simple rebuild will typically suffice.
Mike
Aug 12, 2008 | Jura Capresso Impressa E75 Espresso &...
18,684 people viewed this tip
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
