Tip & How-To about Televison & Video
LAPTOP to TV Connection
Many people today want to connect their computer to a TV. Most HDTVs today have a VGA input for computer hookup. Most laptops also have a VGA output for external display. Using a male to male VGA cable, the computer can use a HDTV for a display. Sound is connected using a 3.5mm audio cable. See this web page for complete details.
http://columbiaisa.50webs.com/laptop_to_tv.htm or this webpage
http://sites.google.com/site/columbiaisa/laptop_to_tv
The screen resolution setting determines how much information is displayed on the display screen. It is measured horizontally and vertically in pixels. At lower screen resolutions, such as 640 x 480, fewer items will fit on the screen, but they will be larger. At higher resolutions, such as 1600 x 1200, more items will fit on the screen but they will be smaller. The resolution options will vary with each computer based on the video card device, monitor size, and video & monitor drivers. If the screen looks distorted or fuzzy, then you may have an incorrect screen resolution size set for your monitor. In Windows you can change the screen resolution to match the TVs capabilities. Go here to view a video on how to change screen resolution:
http://windows.microsoft.com/en-US/windows7/Change-your-screen-resolution
Televison & Video Logo
Trying to connect Laptop VGA to TV Component (RGBHV) INPUT
Computer VGA to TV AV RCA S-Video Composite Converter, Costech HD 1080P HDTV Video Cable Converter Adapter Plug and Play for HDTVS, Monitors, Display, Laptop, Desktop, PC
Go to Amazon and for $10 solve the problem
Feb 04, 2018 | Mitsubishi Televison & Video
how do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
No problem, wondering if I'm able to connect this TV to my laptop to connect to the internet and if so what do I need to do this.
Yes, you should be able to. You will need to buy a $20 adapter. Sewell Direct sells them, also Amazon.com. They are called VGA to RCA composite video converter. This will convert your laptop's VGA output to RCA composite video for connection to your TV yellow video input. Connect an audio cable from laptop's earphone output to the TV's RCA audio inputs (white and red) using a 3.5mm to RCA adapter cable available at Radio Shack for about $10. This will work. You can see everything that the laptop displays on the TV. You can even hookup a VCR to record it all.
Aug 04, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
i have a s-video output and hooked it up though a cable to the yellow rca on the back of the tv. how do i get that to work and watch the computer screen on tv
1. This depends on the ports on your laptop and tv - if you have a vga port on your laptop then connect a cable to that and go to either the RGB or VGA on your TV. You can also get RGB to scart conectors so ther eare a lot of options! try your local Maplins for the cable (or look on eBay). Do a google image search to identify the connectors you have.
2. High-definition TV sets have several options of input ports and cable connections available. It's even possible to connect a computer to most HDTVs to get its picture quality. If your laptop computer is designed so it can plug into a standard computer monitor, you can easily plug it into an HDTV set, and you may have a number of options to connect it with. You must connect the video and audio separately in most cases. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Easy Instructions Things You'll Need:
  • Laptop computer
  • HDTV set
  • Audio and video cables
  1. Step 1 Check the output ports on your laptop computer. There are three types of ports that can work with this connection: S-video (a circular port with pins in the middle), VGA (a square/trapezoid like port with pins in the middle and two screw pins on the sides) and DVI (a longer version of VGA).
  2. Step 2 Compare the ports on your computer with the input ports on your HDTV. DVI has the best quality, but not all TV sets will have these. Most HDTVs will have VGA and S-video (VGA has the best quality).
  3. Step 3 Connect the computer's output to the TV using the best cable connection that you have.
  4. Step 4 Connect the laptop's audio output to the TV's audio input that works with the video. In most cases, this requires a stereo-to-RCA cable, which has the single rounded plug with two black bands at one end and the red and white RCA plugs at the other.
  5. Step 5 Turn on the laptop and the computer and tune the TV to the correct input channel. Tune it to "Computer" only if you used the VGA connection; if you used S-video, tune the TV to that input channel.
Feb 27, 2010 | HP Pavilion dv1000 Notebook
418 people viewed this tip
Top Televison & Video Experts
