Tip & How-To about Refrigerators
Fixing a failing Bottle cooler
99 times out of 100 when we hear about a bottle cooler which is not died but warming the beverage instead of cooling it this is what we do.
1. Pull the machine away from the all so we can work on it.
2. Empy the eveything out the fridge and tape the doors shut. This is important as when moving a fridge which has sliding doors they can bite you!
3. Inspect the back, front & under side of the fridge for a carpet of dust and fluff. This blanket is insulating the motar and making the fridge under perform or actually heat up the contense.
4. Clean way this fluff and dust, making sure air vents are free flowing.
5. Lastly, when pushing the fridge back into position, remember to leave standing for at least 4 hours allowing the chemicals to settle before switching on.
If this doesnt work, you can always get a great deal at www.gmsuppliesltd.co.uk
Refrigerators Logo
danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
how do you change a evaperater fan on a Beverage air bottle cooler?
Its a pain but reach down in there and pull the screws out and remove the panels. Its in there honest! Hope this helps good luck.
Jul 12, 2014 | True TD-50-18 Beverage Cooler
Cooler fan runs but does not cool anymoreanymore
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 16, 2010 | Coleman Electric Cooler 40 Beverage Cooler
No longer cools.
This refrigeration system may be under extended warranty.
Otherwise check the compressor start relay for loose or burned contacts.
Mar 08, 2009 | Avanti WC494D Compact Wine Cooler Beverage...
257 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
