Tip & How-To about Computers & Internet
FREE DIAGRAMS AND ILLUSTRATIONS
I have noticed that many people need diagrams or illustrations of what they are working on. It makes the work much easier when you know what something looks like or where it's located. Well I found this site that has hundreds of diagrams and illustrations for most imports and domestic vehicles, and it's all free to print. Check it out.
http://autorepair.about.com/cs/techtips/l/bl_pic_index.htm
Computers & Internet Logo
NEED AN ILLUSTRATION FOR REPLACING A VEHICLE SPEED SENSOR FOR A 1996 FORD WINDSTAR
If you browse the FIXYA site you'll find some good iformation already establish by some fixya members. I don't think i could anymore info. Good luck.
Nov 10, 2014 | 1996 Ford Windstar
1986 dodge 600 temp gauge and fan not working
If you go to Autozone.com site and register your vehicle, you can get free wiring diagrams and fusebox layouts for your car. Another site is alldatadiy.com
Years ago, some Libraries would buy books which illustrated the wiring on many vehicles.
Finally, do a Web search using the header "1986 Dodge 600 wiring diagrams (or illustrated wiring)"
I hope my solution is helpful, please rate my info.
Nov 06, 2012 | 1986 Dodge 600
need power window wiring diagram
Year, make, model, and engine size? If you look in between the door and the body of the veicle you should see a rubber boot. Inside of that boot is the door wiring harness. I would bet there are broken wires in that section that need to be repaired. Match the broken wire colors and you should be good to go. I find it a lot easier to pull the harness completely out of the door when making these types of repairs. Something's the harness will also be able to be removed from the vehicle allowing you to make repairs on the bench, which makes it a lot easier. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 31, 2012 | Cars & Trucks
It's not starting and i notice that no lights come on. I know that one problem is the battery. I don't know the other problem because it wouldn't start with the battery working. So I don't know if the battery was low or it's something else too
Try to charge the battery and make sure the terminals are shiny and clean by brushing with a wire brush.
Also make sure the battery bolts are tight.
If the battery is older than 3 years, it might be time to get another fresh new battery from Walmart or Sears or your local parts store.
This will make it easier to eliminate the battery as the problem.
Aug 07, 2010 | 1993 Dodge Caravan
how do i replace the wiper blades?
pick blade up and press the pins togethor and pull out and slide the new ones in recommend the rain x blades work really good
Nov 27, 2009 | 2008 Honda Civic
260 people viewed this tip
David Payne
David Payne
