Tip & How-To about Office Equipment & Supplies
Search the Manual for Olympia Texstar MF
I have an olympia mf but not the manual and olympia disk, files is not compatible in a pc (format question on pc)
If you have ? Thanks to all !
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
After I format my hardisk for several times and the file system still showing RAW. how to make it ntfs.
Install the drive on a working computer and access through disc management. that will allow you to initialize the drive and format it ntfs. Goto my computer right click select manage select drive management. This works on XP if you have other OS than search for disc management for your OS.
Aug 29, 2013 | Seagate Computers & Internet
Error on windows load
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
May 10, 2008 | Dell Dimension 4600 PC Desktop
818 people viewed this tip
jasbo
jasbo
