Tip & How-To about Office Equipment & Supplies
Search MANUAL for OLYMPIA TEXSTAR MF
I have an olympia mf but not the manual and olympia disk, files is not compatible in a pc (format question on pc)
If you have ? Thanks to all !
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
my HDD HXD 1TB light but don t work
I'm assuming you have a 1TB external hard drive ... that you can connect to your Mac or a PC, e.g via the USB (or Firewire) port.
If the disk drive is formatted for a Mac, the disk (files, format) may not be compatible on a Windows computer. The reverse is not usually a problem.
If you plug it into the Windows computer, and the disk content doesn't show up (quickly), then the disk/file system has been corrupted. It's not likely the disk that is the problem. It's the contents that's all "confused".
If you need to use the external disk drive on both the Mac and PC, try formatting it on Windows (first). Then add contents to it, and it should work for both the PC and the Mac
Feb 19, 2014 | Computers & Internet
After I format my hardisk for several times and the file system still showing RAW. how to make it ntfs.
Install the drive on a working computer and access through disc management. that will allow you to initialize the drive and format it ntfs. Goto my computer right click select manage select drive management. This works on XP if you have other OS than search for disc management for your OS.
Aug 29, 2013 | Seagate Computers & Internet
1,117 people viewed this tip
k24674
jasbo
jasbo
