Tip & How-To about Televison & Video
LCD TV care for long term service?
Large LCD TV is fragile. LCD can not be touched while power is on. Thin film ransistors maybe shorted out and color permanently displayed. Replacement is very expensive.
Televison & Video Logo
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
My Garnin Nuvi 760 has stopped responding to touch screen. It starts and eventualy opens a map but nothing I touch on the screen will respond.
The problem is probably with touchscreen (a thin film on screen)
You can try order a replacement touchscreen on ebay and replace it yourself
Tip: order a couple of them, they are cheap but extremely fragile
May 19, 2011 | Garmin Nuvi 760 Car GPS Receiver
what are the possible disadvantages of computer monitors?
Monitors, otherwise known as displays or screens, currently come in two formats: LCD and Trinitron ("the boxy thingy").
LCD pros: Flat, low radiation (as far as I know) LCD cons: displays can either come with or develop "dead pixels" - pixels that remain a solid color or display black, are very fragile - pressing the display surface is not "healthy" for the display
Trinitron pros: deep color Trinitron cons: relatively moderate-to-medium radiation
Both types of displays can suffer from "screen burn" - if an image is displayed for too long (several hours/days) it will permanently "burn" itself into the display and be visible at all times.
Jul 15, 2010 | Computers & Internet
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
178 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
