Tip & How-To about Computers & Internet
Portege m200
How to work the pen tablet with lcd or with the cover
Computers & Internet Logo
My replacement stylus won't work for my MousePen 8x6 tablet
Is the stylus the exact same one that came with the tablet? ( I own this tablet.)
If it is, remember to place a AAA size battery in the pen. To open the pen, simply grasp the upper and lower dark purple parts, the ones on either side of the lighter purple band, and pull them apart from each other. Place the battery negative side on the spring, twords the tip of the pen, and the positive side under the small metal hook. Replace the cover, taking care to align the sheet metal hook with the pen clip. (there is a notch there for it to fit inside of.) Now tap the pen against the tablet to wake it up. It should work perfectly. If it already had a battery in it, remove and replace it to restart the pen. If it still doesn't work, try a fresh battery.
~KenjiFox
Jan 07, 2011 | Genius MousePen 8x6 (MOUSEPEN8X6)
pen not detected on especific zones of display
it's a digitizer (hardware part of LCD screen) problem, U can try to buy that part and replace it or just squeeze a little bit LCD screen on the edges around (don't squeeze the screen itself but just black plastic frame around the screen) - it helped my Toshiba for a while :)
May 18, 2009 | Toshiba Portege 3500 Tablet PC
M200 Tablet - cannot write on tablet
i lost my software that came with the system and want y
to install the operating system.
purchasing the software and install it. i downloaded drivers and yet the pen did't work.
Dec 05, 2008 | Toshiba Portege M200 Tablet PC
Tablet PC 2005 Input Panel won't work.
Are you pressing down firmly enough? If not, sounds like the digitizer may have a problem... The digitizer is the layer in front of the lcd, it's job is to pick up the signal from your pen and send it to the motherboard. The motherboard should have two connections to the screen, one to the lcd itself and another to the digitizer. If you remove the screws on the bottom of the tablet you can take off the keyboard and see if both are connected right.
Oct 18, 2008 | IBM ThinkPad X41 Tablet PC
Pen Tip Not Working
I had the same problem and called Wacom Customer Care at 360-896-9833... I was informed that the pen was defective/ broken and needs to be replaced. This can be caused by being dropped and such. I was told that i should keep the pen on the stand or a eyeglasses case when not in use.
If your tablet is under a year old, warranty will cover the cost of the pen with proof of purchase. Other than that, you will need to purchase a new pen (about $29.99 from Wacom & online).
Unfortunate, but great to know.
Jul 16, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
171 people viewed this tip
David Payne
David Payne
