Home | All Products | D52W20 52 in. Rear Projection HDTV-Ready Television | Tips
General tips to repair LCD flat panel and Rear Projection TV's
IrishDruid
By Guru IrishDruid
Rank: Guru
Rating: 88%, 1775 votes
posted on May 03, 2008
Very Helpful
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Was this helpful?
Yes
No
3 people thought this was helpful
Comment #1
posted on Oct 07, 2008
ginko
By Guru ginko
Rank: Guru
Rating: 89%, 4917 votes
Hi
I agree, I got here from a premium post, the procedure suggested is not safe.
Servicing and troubleshooting TV is dangerous and a far more complex procedure than the one described here.
Y ou do not work on a TV board if you do not have a solid experience in soldering and electronic testing.
You also need to unplug power one hour before servicing the TV.
If you do not have done this several time before, you will better call a technician.
There are differences in servicing a $100 small electronic powered by a small battery and servicing a $3000 TV with high voltage circuits.
Sorry , but that is the truth.
Comment #2
posted on Jul 22, 2008
freezespray
By Guide freezespray
Rank: Guide
Rating: 89%, 4 votes
Usually heating a chassis to get it to play, then "just leaving the tv on" is not a reliable or safe way to address a problem.The set is likely to get shut off accidentally or when the line power drops out, like in a storm
Also pulling defective components from the board with pliers will surely destroy the board.
The parts to be replaced should be carefully and completely desoldered, then removed.
Safety first, most sets require the line cord to be disconnected, or the back cover won't come loose.
Can you Help with these Projection Televisions problems?
RCA D52W20 52 in. Rear Projection...
rca 52 inch the picture is kinda like 3-d how do i fix...
hello i have a question. I have a 52 inch rca hdtv that...
Our RCA HDtv 45 in projection tv will not turn on. The...
i need a high def cable but the ones tn the stores are...
how to remove dvd from d52w27d
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
