Tip & How-To about Computers & Internet
Dell Dimension 4550 Ethernet Driver Installation Guide Here are the steps on how to properly install the Ethernet Driver for the Dell Dimension 4550: 1. First click this link to download and install the Intel Chipset Driver for your computer model. 2. After the driver installation is complete restart the computer. 3. Then click this link to download and install the Ethernet Driver. 4. Restart the computer again. Other software downloads for Dell Dimension 4550 can be found here.
Computers & Internet Logo
driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
Sep 18, 2012 | Dell J0592 / 0J0592 DIMENSION 4550...
Dell Dimension 4550, OS = WINXPPRO. Just reformatted and reload OS. Got and installed drivers from Dell.com. System sees onboard ehternet but says no driver for a PCI communications device. Cannot locate driver. System will not go to inet. Can you offer suggestions?
Dell Dimension 4550 Drivers
From the above link you can download the required drivers. There are two drivers available for Broadcom and Intel. I suggested try the Intel Drivers (as your system may be having the Intel based Ethernet)
To PCI communication Controller (Modem) you have to install the Modem Drivers
Trt Eicon (recommended) Or broadcom conaxant etc
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | Dell Dimension 4550 PC Desktop
dell dimension 4550 ethernet driver please
Dell dimension 4550 Ethernet Driver Installation Guide
1. Go here to download and install the Chipset - Intel driver.
2. Restart the computer.
3. Then go here to download and install the Ethernet driver.
4. Restart again.
Aug 20, 2010 | Dell Dimension 4550 PC Desktop
Dell Dimension 4550 Ethernet Hardware not working, cannot reload drivers.
Have you tried restoring your operating system? If not, please do so. There is a problem with operating system and the driver of your ethernet hardware. There might be a conflict on it.
Jul 12, 2010 | Dell Dimension 4550 PC Desktop
I install new windows and ethernet controller is not working and I can't get on the internet? What can I do?
Purchase a USB memory-stick.
On another computer with Internet access, access: http://support.dell.com and select "Downloads and Drivers". Select "Dimension". Select "4550".
Select "Network Adapters". Download the device-driver, copying it to the memory-stick.
Move the memory-stick to your computer, and "install" the device-driver.
Feb 02, 2010 | Dell Dimension 4550 PC Desktop
229 people viewed this tip
David Payne
David Payne
