Tip & How-To about Dryers
How it works: GE clothes dryer
The GE dryer has a 120 volt motor. In case of lint build-up and air restrictions manufacturers install a non-resetable limit which is tied in with the door circuit. When the dryer overheats above 300f this limit kills the dryer.
Their is another 250f limit that mounts on the opposite side of the pan.
The control klixon mounts on the blower housing
The 2 smaller terminals fire off a small heater inside the control which makes it shut down faster for delicate and perma-press cycles. Clever no? The heater element mounts on the rear of the dryer
The drum rides on a central bearing in the middle on the back side. This small plastic bearing will get thin and begin
to sing a song: squeek, squeek, squeek!
The front of the drum rides on slides. They get thin and tend to pinch clothes bind on the drum mount and generally make the motor bog down in some cases.
In the past the old school GE dryer drum rides on these glides:
You get into the dryer by opening the door and removing the screws holding down the top:
Note: I worked one recently that simply had spring clips between the top and front panel, hay we don't need no stinking screws!
After popping them clips on each end the top comes off there and has a green grounding wire that attaches to it.
Then disconnect the screws and lid switch and remove the front panel:
Push downwards on the idler and release the belt. Grab holt of that belt and use it to help you remove that drum:
Once you get that drum out the innards look like this:
The belt goes around the drum with the ribbed side down. A twisted belt is a belt that is gonna get destroyed the minute you start that dryer. Make sure it ain't twisted. Note: GE uses different sized belts and different parts for components per production run. Make sure you give your model number (inside the door) to get the correct belt,element, glides, bearing,etc. They are not all the same. You can cut yourself easily on the stamped metal frame so be careful when wrangling that belt back on:
Tip: To get the belt on there you gotta have 3 hands. Yank the idler from right to left till it is over the motor pulley then get a friend to hold that in place with the broom handle while you loop the belt over the top of the idler and under the motor pulley; then grab the idler and ease it back enough to remove the handle. Then let it go and all will be well. Give the drum a turn by hand and see if the belt is twisted. If the heater element is broken their is no need in buying the whole pan.
The kit comes with directions to pre-stretch the coils to 42 inch's for the inner circle and 48 inch's for the outer circle. You want no gaps on in your restring because that would make the coil die quickly.
Lets talk gas heat for a moment:
The gas dryer has the Flame sensor, ignitor, and coils like you might see in many other makes of gas dryers. When the control calls for heat it powers up the gas assembly. The ignitor, flame sensor,and coils are all energized at once. The coils will not operate unless the resistance in the circuit changes.
To do it the ignitor and flame sensor has to be removed from the circuit.
The flame sensor has a bi-metal strip in it which opens and kills power to the ignitor.
With both the flame sensor and ignitor out of the circuit the coils yank open spring loaded valves and the raw gas ignites on the hot surface ignitor.
When the heat is about 160f in the drum (which takes no time) then power is removed from the gas assembly the heat goes off and the clothes tumble on till the temp inside the drum gets to 105f and then power is once more applied to the gas assembly. If the heat works some but quit those coils are getting hot and quiting.
Nothing is hard about repairing a good old GE dryer. I am including a video I found online a guy made on an older GE dryer; so that you can get an idea on fixing both older GE dryers and the newer ones.
That's all the smart pills I have for today.
Rate it or Hate it:
Dryers Logo
Why does high limit switch keep blowing?
Check for lint build up inside the machine, especially around the air exit duct as any restrictions can cause the machine to build up heat higher than normal. The high limit safety is a fire preventative device.
Nov 15, 2015 | LG Dle2301r Front Load Dryer dle2301r
does not heat
Try resetting your circuit breaker. Look for lint buildup in your vent and your lint filter housing. If you see excess lint you might have a tripped safety or a blown duct fuse. Get a cheap meter and check each of the safety components and the air temp control stats for continuity. Check the heating element. If all of those check good then check the timer. If the timer is ok then power from the wall might not be there for heat. The motor works on 120 volts but the element needs 240 volts on electric models. On gas models your flame sensor, ignitor, or solenoid coils are suspect as well as the limits and safetys just as on an electric model. More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 07, 2011 | Dryers
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the wall, then up after only about 8 inches, then goes up to what I believe is between the floor joists and out the wall. The outside has a venting louver but there is no movement of air with the dryer on. Is there a clog in the venting or is maybe the blower motor or belt has become weakened not to be able to push the air outside?
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
GE dryer will run but no heat
this issue is almost always a breaker tripped, or restricted air flow. Verify air flow by removing hose at back of unit, and form opinion of air flow; hook back up and see if you have the same air flow outside the building. Any restriction will trip thermal limiters (auto resetting).
Breaker needs to be turned FULLY off and back on, then test for heat.
Mar 26, 2011 | GE Dryers
dryer will not dry clothes in single cycle, and towels smell burnt why?
Check the entire air vent system for lint obstruction. Remove the lint filter and wash in hot water and detergent--fabric softener sheets will build deposits on this screen, which restricts air flow.
Sep 07, 2009 | GE DBSR453EBWW Electric Dryer
5,706 people viewed this tip
Top Dryers Experts
