Tip & How-To about Microwave Ovens
Home alone for home electronics
I have come across many complaints of home systems not working when one comes back after a long holiday. This made me think to give some tips so as to take care of your dear products while you are away.
To start with disconnect cable line and power to your TV and Home System , Disconnect power generally to all the other appliances if the period of absence is more than a month.
Now the most important part is that in many cases moisture build up, condensation and insect infestation can be the biggest problem apart from power related issue for which we take off the cable and take power plug off.
Cover the concerned appliance with a GOOD BLANKET to keep it warm within. If there are devices with battery you can remove battery or keep them connected to power specially cordless phones. But laptops can be kept off power. Micro waves must be clearly covered as the kitchen appliances are most vulnerable to such problems.
when you return after the holiday the clocks might have to be set after switch on .
However many may dispute to say that the power can be put on but in many cases lack of human interference results in insects to barge in and cause havoc. Hence if you in such a threat and environment, try this out.
Also you may end up saving power by switching off the fridge during this long period.
Hope this tip finds use with a purpose.
Microwave Ovens Logo
264 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
