Tip & How-To about Plumbing
Home Plumbing Tips
Plumbing is a learned skill, and often mistakes are made because the home handyman does not have the knowledge of the proper tools, compounds or pipe for the job. All plumbing systems get clogs eventually and a lot of time can be saved on a plumbing job if you follow a few simple rules. You can fix the plumbing problem by yourself if you have the right tools, know the technique, and you are prepared to do it. The tools aren’t all that expensive, and sometimes can be rented, but if after a few attempts you can’t get the clog loose, call a San Diego professional plumber.
Plumbing Logo
Where can I get the tools for plumbing?
Tools are the ornaments of plumbing professionals. Without the tools, the plumber is not able to do his work. For doing plumbing at home on your own, you should have right tools for it. For proper tools, you should have an idea about tools, and you can get a best options on Arvada Plumber
Mar 21, 2017 | Plumbing
What are the uses of plumbing?
Plumbing nowadays is specially used for small quantity water consuming in society building or in factory main supply from where the distribution of water is done via pipe line system called as plumbing. It is also said that, plumbing is the collection of connected pipes, it can be done in commercial as well as residential areas. The main goal of Assistance Plombier 77 is to reduce the wastage of water and to keep the environment clean and healthy.
Nov 12, 2014 | Watches
Can a Kenmore 97282100 dryer for natural gas, be converted to work on propane for a reasonable cost, let's say <$100?
If you do it yourself, it absolutely CAN be done for much less than that. The conversion kit basically consists of changing the orifice/s on the burner/s, changing the spring in the gas valve and setting the proper gas pressure. Most all kits come with basic instructions. Make sure you use a gas approved pipe thread compound (pipe dope) to prevent leaks.
If you hire an appliance repair tech or a handyman with good solid appliance skills you could expect to pay anywhere from $75 to $150 for the job.
You can likely save some money by having the kit on hand for the tech. (let them know when you schedule the job, so they won't have to track down the kit for your unit.)
Oct 10, 2009 | Kenmore 72602 Gas Dryer
774 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
