Tip & How-To about Heating & Cooling
Make you A.C. run more efficiently.
If you turn the fan speed down on your air conditioner when the temperature is turned down you will have better results. When the fan speed is too high the condencer is likely to freeze up and you won't get as much cold air from the unit.
Heating & Cooling Logo
how do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
high low fan motor
Your main concern is the temperature difference across the indoor coil for both heating and cooling. When you turn your thermostat from auto to on, you are on high speed.
If you have long duct runs and little return air registers then high speed
would help cool the house better. However in the heating mode, you
could lose up to 10degrees by having the high speed setting.
What they installed is sized for your house and the speeds should not have to be changed unless the ductwork is not sized right for the house.
Cooling should be High-Black wire.
Heating should be Low-Red Wire.
400cfm equals a ton of cooling= 1200 sq. foot, For cooling you need
High speed. For heating it is whatever the temperature rise across the
coil is, which is located on the furnace/air handler.
Jul 13, 2010 | Goodman CLQ36AR49 Air Conditioner
air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
how do you set the temperature
If you have an air conditioner with a temperature display, use the up or down arrows on the touch pad to change the temperature setting.
However, if you have an air conditioner with only a dial that goes from 1 to 8 (or whatever number), turn the dial up as high as it goes and put the fan speed on high. When the desired comfort level is reached, slowly turn the dial down until the compressor just shuts off. You will be able to hear when this happens.
If the temperature gets a bit too warm turn the dial up in small increments and wait an hour or so to see if your comfort level is reached.
Jul 03, 2009 | Heating & Cooling
161 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
