Tip & How-To about Televison & Video
Digitial channel tune in and set up
If you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
Televison & Video Logo
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
i know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not tuned to a channel. The mute works OK.
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
i have lost channels 5,itv 3,and itv 4,and do not know how to retune my tv, all other channels appear to be alright slightly confused when i press the menu button and not know which links to follow?
All Freeview channels need re-tuned after 30th September.
To re-tune your Sony TV...
1.Press Menu button then go to settings...
2.Scroll down the menu icons until you get to 'Digital Set-up'
3.Press enter/centre key next to direction arrows
4. Select spanner icon and digital audio tuning.
5. You will then be asked if you want to start digital audio tuning.
6. Press enter/centre button....and thats it!.... TV will automatically re-tune.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
418 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
