Tip & How-To about Refrigerators
Dishwasher Tip
It is probably not necessary to pre-wash your dishes like some people do, but it is important to scrape off leftover food from plates and bowls. Rinse and then load into the dishwasher.
Refrigerators Logo
What is the best way to sanitize my dogs bowl?
Sanitizing a dog bowl is quite simple. I recommend following these easy instructions:
Scrape off any excess food and rinse the bowl with dish soap and a sponge.
2. Rinse off and repeat step 1 if there are any leftover food particles.
3. Scrub the bowl with a fine steel wool pad and a mild cleanser.
4. Using a heavy steel wool pad you should apply more cleanser and scrub thoroughly.
5. Lastly, give the bowl one last scrubbing with a fine steel wool pad and then dry the bowl with some paper towel.
Aug 26, 2012 | Alessi Pets - Others
I have a whirlpool gold quiet three.It has never been used I do not have the instruction manuel. help with starting please
Hello.
If you've just installed a Whirlpool Gold dishwasher, consider yourself truly liberated from the drudgery of standing at the sink washing plate after plate and saucepan after saucepan. You'll find it much easier to keep the kitchen clean as your dirty dishes are hidden away in your new appliance and all you have to do is wipe down the counter tops and switch the dishwasher on when it's full. However, to get the maximum benefit from your new piece of equipment, it's important to use it correctly.
Instructions
MATERIALS NEEDED WHEN OPERATING.
* Dishwasher detergent
* Dishwasher rinse aid
Preparation of Dishes
1 Scrape leftover food off the dishes and make sure no other hard objects such as small bones or toothpicks remain on them.
2 Remove sticky labels from any newly bought food containers you are washing for the first time.
3 Make sure any leftover coffee, tea, soda or wine has been poured out of cups, mugs and glasses.
Loading the Dishwasher
1 Place cups, mugs and glasses in the top rack with the open ends pointing downwards. Cups and mugs should go along the left and right outside edges, with glasses beside them. Position small plates and saucers in holders along the center of the rack running from back to front.
2 Place larger plates and bowls in the bottom rack, which is also where casserole dishes and saucepans should be washed. Avoid overlapping bowls and plates, because it is important every surface is open to the water directed around the dishwasher's interior during the program.
3 Create a flat surface on which to lay saucepans and larger dishes by collapsing some of the plate holders on the bottom rack, if your model dishwasher allows. Lay them open-end down to allow the water to be directed around their interiors.
4 Position dirty saucepans at the rear of the bottom rack with the open end facing the back of the machine's interior, if your machine has a "PowerScour" facility.
5 Place silverware in the silverware basket with sharp items pointing downwards. Alternate the direction in which you load spoons to prevent them "nesting" together, which stops water reaching every surface.
Detergent and Rinse Aid
* 1
Place detergent in the dispenser just when you intend to run the wash cycle, not before. If you're using standard powder or liquid detergent, be guided by the hard-water and soft-water indicators. These are lines marked in the side of the dispenser. In areas with soft water, fill to the soft water line and in hard-water areas fill to the hard water line. If you prefer individual tablets, follow the manufacturer's instructions.
2 Add rinse aid immediately when the rinse aid indicator reaches the "add" level. Turn the cap on the rinse aid dispenser to "refill" and lift it away from the dishwasher. Pour rinse aid into the opening until the indicator reaches the "full" mark and replace the lid. Make sure the lid is tightly in place.
3 Adjust to a higher setting on the arrow adjuster, located inside the dispenser, if you feel more rinse aid is needed during a wash cycle. You can do this by inserting a flat-blade screwdriver into the center of the adjuster.
Starting the Wash
* 1 Check that the spray arms can rotate freely before closing up the dishwasher.
2 Turn on the hot faucet at the sink closest to the dishwasher and let the water run until it is hot.
3 Close the door firmly and select the wash cycle you wish to use. Depending on which model you are using, you may wish to activate additional options during the cycle such as "Power Scour." These options should also be selected at this stage.
Thanks.
Nov 03, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
my dishwasher is not cleaning my dishes
Hi btoma313,
Find some info in the Tip below, on what to do if your dishwasher is not cleaning properly.
DISHWASHER NOT CLEANING PROPERLY...
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 19, 2011 | Maytag Dishwasher
IT is leaving food on the dishes
You do not have to prewash your dishes before loading them. In fact, by prewashing, you actually defeat the purpose of most dishwasher detergents. These detergents are activated by the grease and oils in food and work better. You should only scrape your plates of solid materials that are not recommended to go into a dishwasher (i.e., celery, popcorn kernels, tough chunks of meat, gristle, etc.).
If you are getting food particles on your dishes, this is known as "redeposition". Most commonly it is caused by food particles trapped in the filter of the main wash pump. You will need to remove the lower spray arm and access the filter screens and clean them of all debris.
If you need further assistance on how to disassemble your dishwasher to access the filter, please post back with your MODEL NUMBER. I hope this information is helpful to you.
Mar 29, 2010 | Dishwashers
Food still left on plates and food still retained in washer
hi,
the reason you are getting poor wash results is the spray arms are more than likey blocked. Remove each arm and check the holes are clear of any blockages as this is where the water sprays from and cleans the dishes.
Dishwashers can only take away food that can turn to liquid, they are not sink errators unfortunately. it is reccomended that you scrape the dishes prior to loading the dishwasher.
Jan 22, 2010 | Bosch Dishwashers
203 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
