Tip & How-To about Grilling
Tip on Grilling
When grilling meats, it is usually best to turn the meat only once. When grilling meat to a medium or greater doneness, use the lid to assist in cooking. This will decrease the cooking time by applying heat to all sides of the meat at once.
Grilling Logo
meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 | Grilling
How to cook a brisket. I ahve lost my manual.
Hi judyyates...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
I will also include a link that will interest you below.
Please take time to rate me.
http://www.smoker-cooking.com/howtosmokeabrisket.html
Sep 24, 2011 | Brinkmann Sportsman Charcoal Double-Grill...
do you put the wood chips directly on the heating element?
Hi bobsbbq3u...
I am sending you some smoking information on how to use your smoker..
Sep 07, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
i do not have manual for using brinkman gourmet charcoal smoker
Hi tsanelli...
I could not find your user manual on the net, but I have this..
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
Aug 27, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
how do i use my smoker
Hi
1... Marinate or place a rub on the meat you will be cooking/smoking, and let it sit for a few hours in the refrigerator covered or covered in the refrigerator overnight .
2...Cover your wood chips with water(and if you wish you can add some Jim Beam or Jack Daniels Whiskey or some other flavorfull liquids in a bowl with the water.
You will want the liquid 1 inch above the wood chips that you are going to use for smoking , use a flat piece of metal (pie pan with jars of water sitting on it or other flat object and weights) to weigh the wood chips down underwater and leave them to soak in the liquid for at least 2 hours.
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal as your heat, source ,you will add your smoking wood later.
Once the wood or charcoal is coated with a gray ash, you can put your meat on the racks.
I would place an aluminum throwaway drip pan or other type of drip pan under the center portion of the smoker or drip area of the smoker to catch the juices from the meat that will be turned to steam to flavor and tenderize your meat.
Close the lid and do not open it unless you have to add wood chips,wood or charcoal during the cooking process.
If you have air vents then you will adjust them to maintain the proper tempreture.
5...Continue adding wood chips to the tray as needed during the time you are cooking to maintain the smoke and the heat at the proper tempreture.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips,charcoal or wood only once per hour.
6...Apply your sauce if you use one to the meat one hour before the meat should be done.
Test your meat with a meat thermometer for an internal tempreture of 160 degrees for medium and 170-190 degrees for medium well to well done.
Note: When you open the door or lift the lid to apply the sauce you will need to close it as quickly as possible to avoid loosing the heat and smoke in your smoker.
If you leave it open too long it will allow the heat and smoke to escape and then you will be increasing the smoking and cooking time.
Keep the lid closed as long as it needs to continue cooking until you reach the proper internal tempreture
7...You can start testing your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 to 190 degrees for medium well to well done.
Jul 30, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
1,534 people viewed this tip
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
