Tip & How-To about Keurig B100 Coffee Maker
Keurig B100 coffee maker not brewing
KeuSymptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump.
The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it.
Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work.
Good luck and if you find this helpful remember to thump up vote it
Keurig B100 Coffee Maker Logo
when I try to brew a cup of coffee on my keurig b100 water leaks back into the resevoir and I only get half cups.
If you are experiencing inconsistent brews, there may be some coffee grounds lodged in the needles that pierce the K-Cup packs. This video will show you how to SAFELY clean this area of the brewer
Aug 28, 2012 | Keurig B100 Coffee Maker
my keurig coffe maker says it id "brewing" but
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 09, 2011 | Keurig B100 Coffee Maker
My Keurig wont brew anymore
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 20, 2011 | Keurig B100 Coffee Maker
2,314 people viewed this tip
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
