Tip & How-To about Office Equipment & Supplies
Overhead Projector Tip- best results!!
For best results, slant the screen forward slightly so it meets at a 90 degree angle with the projected image light beam. In not, then a keystone effect results where the projected image is taller on top or on the sides; in other words, the projected image is a parallelogram, not a square.
How do I adjust view from an angle?
Best to have the projector 90 degrees up and down and left to right to the screen. Try turning the projector to move the image left or right.
Aug 30, 2014 | Office Equipment & Supplies
keystone not working
Manual: http://www.mitsubishi-presentations.com/wp-content/files_mf/mitsubishi_manual_xd250ust.pdf
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
angle.
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
bottom of screen is projecting at an angle. Other 3 sides are at 90 degree angles
It is called as keystone distortion. To correct the problem press the "Keystone" button on the projector, then press left, right, down & up arrow buttons to adjust the angle at 90 degrees.
Aug 15, 2011 | Mitsubishi Office Equipment & Supplies
My picture slants in towards the top from bottom
The issue has to do with something called "Keystone". This allows you to set the projector at an angle and project on an angle. When you set the projector on a flat surface, you would need to adjust the keystone to get rid of the "trapazoid" look of the image.
Jan 31, 2009 | Sony Office Equipment & Supplies
Slanted Border- Projector image is not square
Is the image slanted on the bottom as well?
Make sure the projector's throw is pointed directly at the target ie. screen or wall etc. there's not much else it could be.
Jan 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
1,061 people viewed this tip
jasbo
jasbo
