Tip & How-To about Office Equipment & Supplies
Overhead Projector TIp #2
Some people switch the projector on and off to shift the focus of the audience from the image back to the speaker. This also saves the lamp. This is a matter of personal presentation style.
white spots on screen i have changed the lamp
It's probably you have a busted DMD chip, have your technician replace that, better yet buy a new projector because replacing that chip costs almost a brand new unit.
Nov 19, 2011 | BenQ Office Equipment & Supplies
Cannot focus uniformly across the projected screen. This seems to be more than a focus problem in that some areas of the image seem blurry as opposed to out-of-focus. Also, in what may be a related issue, I cannot get the keystone correction to work to straighten image when being upwardly projected.
try bringing the screen up as close as possible to the projector and still get a focused picture. check keystone here and also for image clarity. if you still have problems, check for dust or moisture etc in the optics. check the lamp for a clean front surface. clean the air filter also. Try a different image source for differences
May 20, 2011 | Eiki LC-XB25 Projector Multimedia...
How do I zoom and focus the LV 7350? It is ceiling mounted. I want to make the image smaller so that people in the audience can see the image over the heads of those in front.
There are zzom and focus buttons on the remote if you have it. If not, use a safe ladder and use the zoom/focus buttons on the projector itself.
Good Luck
Aug 13, 2010 | Canon LV-LP11 Projector Lamp for LV-7345,...
can canon lv-53 projector run on USB....
MSRP (USD) : $1,299 Brightness (Lumens) : 1250 ANSI Contrast (Full On/Off) : 300:1 Variable Iris: No Audible Noise: 32.0 dB Weight: 2.2 kg Size (cm) (HxWxD) : 8 x 28 x 21 Std. Lens: Focus: Manual Zoom: Manual, 1.20:1 Throw Dist (m) : calculator.gif 1.3 - 6.5 Image Size (cm) : 86 - 508 Optional Lenses: No Digital Zoom: No Digital Keystone: Vertical Lens Shift: ** Warranty: 3 Years Performance: H-Sync Range: 15.0 - 80.0kHz V-Sync Range: 50 - 100Hz Compatibility: HDTV: 720p, 1080i, 1035i
575i EDTV/480p: Yes SDTV/480i: Yes Component Video: Yes Video: Yes Digital Input: No Computers: Yes Display: Type: 1 cm 3 LCD Native: 800x600 Pixels Maximum: 1280x1024 Pixels Aspect Ratio: 4:3 (SVGA) Lamp: Type: 160W UHP Life: ** Quantity: 1 Speakers: Mono Max Power: ** Voltage: 100V - 240V FCC Class: B Special: ** Status: Out of Production First Ship: Nov 2003 Last Ship: Mar 2006
May 08, 2010 | Canon LV-S3 Multimedia Projector
sanyo projector image problem
Can you describe the issue?
check out fixmyprojector.com
they can fix this problem for you!
Jan 04, 2009 | InFocus ScreenPlay 4805 Multimedia...
945 people viewed this tip
k24674
jasbo
jasbo
