Tip & How-To about Office Equipment & Supplies
Overhead Projector TIp #1
One general rule about projected image size: judge the distance between screen and farthest viewer, divide by six and use this number to figure image width.
how to divide fractions using calculators?
To divide fractions proceed as you usually do with any number. Just make sure to enclose each fraction in parentheses. You may want to remember a simple rule: To divide a fraction by another, multiply the first one by the reciprocal of the other:
(a/b)/(c/d)=(ad/bc)
Sep 08, 2014 | Office Equipment & Supplies
How should I pick the right TV size?
In general, for best image quality and bestexperience you need 32 inches TV for every three meters. For example if in yourliving room your distance from the screen is 6 meters the recommended foryou is 64 inches. I've attached a table with exact s and ranges for yourconvenience Screen Viewing distance range 26" 3.25 - 5.5 feet 32" 4.0 - 6.66 feet 37" 4.63 - 7.71 feet 40" 5.0 - 8.33 feet 42" 5.25 - 8.75 feet 46" 5.75 - 9.5 feet 50" 6.25 - 10.5 feet 52" 6.5 - 10.8 feet 55" 6.9 - 11.5 feet 58" 7.25 - 12 feet 65" 8.13 - 13.5 feet 70" 8.75 - 14.75 feet
Jul 29, 2012 | Furniture
whats the major problem with supergiants
They're big, heavy and awkward to use, and the image is over-magnified for the size of the objective giving less than ideal image quality and brightness. A general rule (especially if using for astronomy) is that the objective divided by the magnification should never be less than 5. With 20x80's it's a less than ideal 4 so you'll miss out on many fainter objects completely. They can be excellent for lunar observation though as the Moon is so bright.
The high magnification also makes them almost impossible to hand hold steadily enough unless a tripod (or monopod) is used, adding more bulk and awkwardness.
Sep 28, 2010 | Zhumell SuperGiant Astronomical Binocular
Create an equation to calculate a change in gear size on a jeep.
If the gears have been INCREASED the speed etc will be less.
Say it's increased by 18%.In theory,at 100mph real speed, the speedo will read 18%less.i.e. 82mph.
If the speedo is driven off the g/box,all this has to be taken into account.
If the speedo is driven off the wheels(and the wheels have not changed at all)All that will happen is the engine revs will have decreased by 18%.
So,To work out the difference.Divide the distance travelled by 100 and then multiply the answer by 82.(82 is the remaining % of the original)
So if 150 miles is divided by 100=1.5
1.5 is multiplied by 82=123 miles.
Hope this helps
May 11, 2010 | 2003 Jeep Wrangler
how many photos can you put on a 80 minute disc cd-r
80 minute CDR's are generally 700mb cds. It all depends on the file size of your images.
700 divided by X meg (x = file size of image) = total number of images
Sep 23, 2009 | Kodak EasyShare M1033 Digital Camera
903 people viewed this tip
jasbo
jasbo
