Tip & How-To about Office Equipment & Supplies
Projection Screen Tip
When mounting a screen on or near a wall, consideration must be given to items such as marker boards, maps, and pictures that will be placed on the wall behind the screen. Be sure to leave enough clearance behind the screen surface to eliminate the possibility of damage.
My Sony KDL-42EX440 will not turn on
Have you tried to do a "reset" ALL modern electronic items often get "locked up" and unplugging them from the wall will often get them going again. Unplug for at LEAST 30 seconds--then try again. If this does not help--the SMPS board may have failed on you. A good repair shop may be able to repair the board instead of replace it.
May 06, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
2005 Chrysler Town & Country MAP Sensor location
The MAP sensor is mounted to the intake manifold, near the throttle body inlet to the manifold. The sensor connects electrically to the PCM.
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 25, 2011 | 2005 Chrysler Town & Country
fallout 3 game of the year edition xbox 360 map problem
Maybe you're following a different marker? I've never had this happen so I'm not to sure what to tell you, sorry. If you didn't know, the markers you place are lighter than the ones for quest.
Jan 06, 2010 | Video Game Consoles & Games
Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 18, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have sound but no picture on my 32 inch LCDHD TV/DVD. Picture flashes for a second an then the screen goes blank. Thanks Bill
This problem is caused by one of thee problems.
1) The inverter board(s) is bad.
2) Power to the inverter board(s) is off.
3) The CCFT(cold cathode fluoresent light) is bad.
Since the picture flashes for a second you may also check for loose connections for the above items.
Here is a simple test you may also try. With the TV on take a bright flashlight and press it against the screen. Look for an image around the edge of the flashlight. This will verify that an image is being sent to the screen.
Mar 12, 2009 | Televison & Video
1,265 people viewed this tip
jasbo
jasbo
