Tip & How-To about Apple iPod MP3 Player
Code?! FORGOT YOUR CODE?!
In order to get rid of the forgotten code and disabled message, we must restore the device.
In this case when the iphone or itouch or similar is giving you a message that its disabled, then we have to first force the device into recovery mode, from which we can do a normal restore.
Note that this removes all the content from your player.
Basically the steps are
1. Take out the usb cable, connect it to the computer, but not to the device.
2. Turn off your device
3. While pressing and holding the home button, reconnect the usb cable to the device, when you reconnect the usb cable the phone or itouch should power on.
If you are low on battery let it charge for a while, then start from thebeginning (unplug the usb from the device)
4. While still holding the home button, until you see a message about "Connect to Itunes" then let go.
5. if not already open, open itunes, you should receive a short warning about recovery mode.
6. do a normal restore from itunes, it wipes the devices and the disabled message and the forgotten code are removed.
Apple iPod MP3 Player Logo
ipad forgotten password
From the apple support site:
iOS: Forgotten passcode or device disabled after entering wrong passcode When you set up a passcode to secure the use of your iPhone, iPad, or iPod touch and then enter the wrong passcode, you may see a a message saying your device is "disabled". Learn what to do if you have forgotten or can't remember your passcode, or if your device displays a message saying it is disabled.If you enter the wrong passcode six or more times, you'll see a message that says one of the following:
  • iPhone is disabled
  • iPad is disabled
  • iPod touch is disabled
  1. Connect the device to the computer with which you normally sync and open iTunes.
    Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  2. If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  3. When the backup and sync is complete, restore your device.
  4. When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  5. Select your device in iTunes and choose the most recent backup of your device.
Hope this helps!
http://support.apple.com/kb/ht1212
Feb 05, 2014 | Apple iPhone 3G
Iphone 5 has been disabled and forgotten passcode
iPhone Is Disabled After a series of more failed attempts, your iPhone displays the same "iPhone is Disabled" message, but with an added "Connect to iTunes" message. At this point, your iPhone shuts down completely and you cannot make any more attempts to enter the passcode. In order to restore the device at this stage, you need to connect it to a computer with iTunes installed. Ideally, connect it to a computer that you've used before for syncing your iPhone.
Apr 08, 2013 | Cell Phones
Ipod 30GB unlocking free code
If you are low on battery let it charge for a while, then start from the beginning (unplug the usb from the device)
Mar 20, 2011 | Apple iPod MA446LL/A MP3 Player
My itouch screen is responding to touch but not doing anything
I would restore the ipod touch using itunes. I have included step by step instructions below just in case you are unsure on how to do a restore.
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPhone or iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Whenever you restore your iPhone or iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPhone or iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPhone or iPod touch to your computer. Select your iPhone or iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option (as seen in the image below). If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your phone).
Once the restore process has completed the iPhone or iPod touch restarts and displays the Apple logo while starting up
If this does not resolve your issue, you most likely have a hardware issue. If that is the case you may be able to get it repaired or replaced by apple for free depending on how old it is. I included the apple phone number below.
1-800-APL-CARE (1-800-275-2273) Good luck :)
Apr 24, 2009 | Apple iPod touch
How do i exit my iphone running on singleuser boot
hey guys... the only thing you can do now is to restore your iphone/ipodtouch...
how to restore:
connect your itouch/iphone with usb to your computer and open itunes... probably itunes will not find your itouch/iphone cause its not booted correctly... so
hold down the sleep button and home button for more then 15 sec. first it appears a black screen and after actually you have to hold down both buttons till this logo with the usb and itunes appears and then itunes said its a problem with your itouch/iphone and you have to restore...
thats all - itunes restores your itouch/iphone and finish :D
good luck guys ;)
Jul 04, 2008 | Apple iPhone Smartphone
4,626 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
