Tip & How-To about Boating
Boat Wax Plus, Removes Water Spots
Boat Wax Plus eliminates days of waxing your boat. Every boat owner needs it!
Boating Logo
how to prevent ice on fiberglass balconys
If water settles it will freeze. you could wrap it with heaters made for crawl space water pipes. Maybe a good wax job with boat wax would help.
Dec 08, 2016 | Refrigerators
WHAT CAN I USE TO APPLY A PROTECTIVE FINISH ON MY PELICAN BASS BOAT
Plastic boat? Probably easiest thing is to use car wax. Pick something with UV protection.
May 27, 2013 | Boating
accurate when still display changing inaccurate
You might have air bubbles trapped on surface of transducer. Use soap on it so water sticks to surface, no wax, oil, or grease.
If transducer is mounted inside the boat, you have air trapped between it.
Jul 12, 2009 | Uniden Qt206 Thru Hull, Digital Depth...
866 people viewed this tip
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
