Tip & How-To about SanDisk Sansa e270 MP3 Player
I need to open on my computer is not syncronizing and
SanDisk Sansa e270 MP3 Player Logo
ignition timing for 96 dodge ram v8 5.9
Ignition timing on a 1996 Dodge Ram equipped with a 5.9L engine is controlled by the computer and is not adjustable. Attempts to adjust ignition timing by rotating the distributor will cause the fuel syncronization to be changed. If the distributor is moved or replaced, fuel syncronization should be checked and/or re-syncronized. This requires the use of a scan tool that can command the engine computer into "fuel sync" mode.
Apr 14, 2012 | Cars & Trucks
how do i use my mobile as a USB modem? that is, connect my laptop computer to the internet using my connected mobile
hello
to cennect to internet using mobile as a modem you need usb cable from your mobile to your computer and application of the mobile like nokia pc suite, once your mobile recognized by pc open the application (e.g. nokia pc suite) then select syncronized by select first the model of your mobile to be used as modem. then click syncronized and after syncronized select connect to internet.
thank you
Mar 07, 2011 | Computers & Internet
how to install firmware version 35.2.002.exe rm 421 on my nokia n 95 8 gb
syncronize your phone with computer,, then install in,,
first install nokia pc suit on your computer from the cd you got with your phone,,
then use the syncronization option
Mar 23, 2010 | Nokia N95 Cellular Phone
I need help downloading music on my mp3 player. How do I get started?
you just plug it in to your computer and syncronize it to the computer and thats how you do it!!!!
Feb 13, 2010 | Coby MP-610 MP3 Player
apple ipod 1gb locked and dont know the combination and cant sync
Connect it to the computer you normally sync with.
Open iTunes then disconnect the iPod.
If that doesn't work you can "hard reset" by restoring it to factory defaults. Doing this also erases everything you have on it so you will lose your movies, music, files, etc.
Connect it to the computer and open iTunes.
Click "Restore" and select "Restore" or "Restore and Update" to make sure you're on the latest firmware.
Good luck.
Feb 04, 2009 | Apple iPod nano
1,394 people viewed this tip
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
