Tip & How-To about Audio Players & Recorders
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
2011 holden cruze radio wiring diagram
2011 Chevrolet Cruze Car Radio Wiring Guide
Car Radio Battery Constant 12V+ Wire: Red/Dark Green
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Dark Blue
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 1? Tweeters
Car Audio Front Tweeter Depth: 1?
Car Audio Front Tweeter Location: 1?
Left Front Speaker Positive Wire (+): Dark Blue
Left Front Speaker Negative Wire (-): Brown/Dark Blue
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Yellow/Black
Car Audio Front Speakers Size: 6 1/2? Speakers
Car Audio Front Speakers Depth: 3 1/4?
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green
Left Rear Speaker Negative Wire (-): Dark Green/Black
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Dark Blue/Black
Car Audio Rear Speakers Size: 6 1/2? Speakers
Car Audio Rear Speakers Depth: 3?
Car Audio Rear Speakers Location: N/A
Car Subwoofer Speaker Positive Wire (+): N/A
Car Subwoofer Speaker Negative Wire (-): N/A
Car Subwoofer Speaker Size: N/A
Car Subwoofer Speaker Depth: N/A
Car Subwoofer Speaker Location: N/A
Jan 02, 2016 | Holden Cars & Trucks
I installed a new Sony CD player in my 1996 Toyota Forerunner and the speakers won't work. The player has power but there is no sound. I did not use a wiring harness but I did have the wiring diagram for the vehicle. Help!!!
Be sure that the wires are connected correctly. If no sound comes out could be speakers are bad, but highly unlikely that all four would be. Could be the stereo amplifier is out. You could try using an amplifier to connect the speakers. One other option run new wire to each speaker to make sure wiring is still good. Constant 12V+ Blue/Yellow or Blue/Black Switched 12V+ Gray Ground Brown Illumination Green Dimmer n/a Antenna Trigger Black/Red Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink Left Front (-) Purple Right Front (+) Light Green Right Front (-) Blue Rear Speakers 5 1/4" Rear Doors Left Rear (+) Black Left Rear (-) Yellow Right Rear (+) Red Right Rear (-) White
Feb 14, 2011 | Car Audio & Video
im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of my speakers. i need sound or speaker wiring diagram from xplod to factory wiring for my vehicle.
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
Wire diagram for installing a radio in a 2000 jeep grand cherokee limited?
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Oct 09, 2010 | Car Audio & Video
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
293 people viewed this tip
 Grubhead
Grubhead
