Tip & How-To about Crafts & Hobbies
How to get wrinkles out of clothes that have been washed
Take article of clothing, and soak over 12 hours in white vinegar.
Then wash as usual, and dry. Works everytime!
Crafts & Hobbies Logo
Moss in water chamber how do I remove
From experience, I usually boil a pot of water (6 to 8 cups ) and let it cool down a little bit. Then I get white vinegar (avoid the fruit vinegars) and add about 5 cups of it into the water. Then I would let the shirt soak in the white vinegar and water for about an hour. Vinegar is a mild acid so it acts as a loosening agent for the stain. After your remove the shirt from the pot in the hour, wash as usual. (preferably with a stain removing detergent like tide) The link below provides other methods of removing moss and grass stains. I hope I helped!
Going Green Grass and Moss Stains
Jan 29, 2016 | 3.1 Phillip Lim Silk Keyhole Tank Top -...
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
black bathing suit smell like mildew - how can I get rid of the smell
LET THE SWIMSUIT SOAK IN THE WASHING MACHINE FOR ABOUT AN HOUR AND THEN JUST WASH AGAIN.
SHERRI
Feb 08, 2011 | Ganz Webkinz Clothing CHERRY TANK TOP
clothes are left with a residue on them. I use
Do you use a liquid fabric softner also ? Marks are usually left on clothes from undisolved fabric softner . Try using dryer sheets instead of washer softner .
Jul 16, 2009 | Washing Machines
730 people viewed this tip
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
