Tip & How-To about Ricoh Aficio 1232C Color Copier
Trouble Shoot and Bullitens
SC120 Displayed instead of SC122 when the scanner home position was initialized 001b BICU engine firmware Install new BICU engine firmware
SC142 Intermittent or continuous 025 Defective CCD (vapour from adhesive) Replace the lens block assembly with one that is not defective.
SC280 In color mode (2C or more) with LT LEF and duplex, SC280 occurs falsely if 5 or more originals are scanned during machine warm-up. 001b BICU engine firmware Install new BICU engine firmware (ver. 1.242.01 or later)
SC280 False detection when the main motor direction changes from backwards to forwards 001i BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.31:01 or later)
SC305 008e Toner drops from the dev. unit, between the charge corona cleaner slider and cleaner driving screw
Clean the screw and slider with a damp cloth.
SC410 Unnecessary SC410 generation 001d BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.262:01 or later)
SC420 Unnecessary SC420 generation 001e BICU (Engine) firmware
Install new BICU (Engine) firmware (ver. 1.275:01 or later)
SC481 022 Torn image transfer belt Install a new PCU.
Ricoh Aficio 1232C Color Copier Logo
send me link viedo ?how to fix this code?help me
SC 120 Scanner home position error 1
The scanner home position sensor does not detect the off condition during initialization or copying.
If restarting your printer does not fix your printer you need a tech to replace some. Could be a bad sensor or bad BICU board.
Aug 15, 2016 | Ricoh Aficio MP1600L Printer
Ricoh 2035 cood sc120
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Apr 17, 2016 | Ricoh Office Equipment & Supplies
lanier LD032
Hi Dwayne:
This error occurs when performing the white level detection. Check:
a - The white board on whether or not this position
b - Glass and Optical
c - UBS Card - (card may be faulty)
d - BICU Card (may be faulty)
e - Check the optics and connectors to the cards.
I have heard that several times after cleaning the mirrors of the scanner worked.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 10, 2011 | Lanier Office Equipment & Supplies
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
3,403 people viewed this tip
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
