Tip & How-To about Vehicle Parts & Accessories
CAR ALARM is in VALET MODE.
This is one of the most commonly asked questions, in the car security technical support field. MOST car alarms require you to turn the ignition on, and press or hold the VALET button. This can usually be found under the driver side of the dash.
Vehicle Parts & Accessories Logo
how do I reset or by pass the factory alarm on a 1996 geo prizm ?
my guess the same way as any 1996 toyota, corolla?
its the same car.
and vastly more common, and documentations.;
try alldata.com , login and read the security alarm pages
login to here free an post to Corolla/.prizm pages. its one section just for this car. ask them.
http://www.toyotanation.com/forum/
Dec 21, 2014 | Geo Cars & Trucks
I have a car security system model SUN-I M10 so I need help how can I conect it to my car . pleas send me wiring diagram . thanks
wiring diagram for car or alarm? if its for the car you dont need one to install an alarm... you can do it out of common sence.... but if its for the alarm i have no clue :) i could search aroound if need be?... cheers hope this helps any further questions just ask..
Mar 03, 2011 | Kia Rio Cars & Trucks
Security light on and will not start
possible ignition problem, after replacing an ignition lock cyl. and housing on a saturn i had to reprogram the alarm system which led me here. turn the key on for ten minuets and wait for the security light to go out and try to start it. if this doesn't work try the same thing 2 more times in a row which should reprogram the alarm. if it doesn't start after the third try you've got a deeper problem that you'll need a professional mechanic for.
Dec 24, 2010 | 1999 Chevrolet Lumina
Insurance
Absolutely yes. There are three types of car alarms:
1. Standard/Active - where your alarm is in effective operation at time of theft.
2. Passive - whereby you have an alarm installed on your car, which at time of theft is not in effective operation
3. Immobiliser - whereby the key of your car must be used to start the ignition, otherwise it becomes immobilised
you can be sure that yours car alarm system is one of the above.
Oct 07, 2008 | ' II' DIY Car Alarm Vehicle Anti-theft...
my battery died after recharging it the alarm buttom needs to be reset. I need to know where the reset buttom is
HI ! I haven' t researched your car for you just yet !
I thought Id quickly mention the common method for reprogramming your alarm & remote, If you still require assistance then just ask me and I will find more about your car :)
Common Methods for resetting/re-learning code
  • Factory Fitted Alarms/ Central Locking / remote comes on ignition key.
Insert ignition key , turn key to accessories / red , press & hold lock/unlock for a few secs.remove key,exit vehicle and try un/lock doors &/or alarm (Some models differ slightly & require engine on or manual use of door locks whilst resetting.
  • Aftermarket /Non-Factory / remote is separately operated
Most use a small back-up battery usually located within the loudspeaker/Alarm unit itself under the bonnet,
Remove this battery for a short period to reset the remote code
The access panel for the backup battery is never in an obvious place. look carefully :)
Jul 14, 2008 | Hyundai Sonata Cars & Trucks
2,918 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
